Author Topic: How to make your own thigh pads?  (Read 2239 times)
kalph
« on: April 11, 2014, 10:14:53 AM »
Looking to make my won set of thighs pads, anybody have any ideas of what you would need to do and materials you would need to create them ????
joeljonno
Re: How to make your own thigh pads?
« Reply #1 on: April 11, 2014, 10:19:37 AM »
Memory foam, elastic, cotton sheets, sewing kit, Velcro fastening.
That'd be a basic one.
Sent from my iPhone 5S using Tapatalk
Twitter - @joeljonno
« Reply #2 on: April 11, 2014, 10:52:20 AM »
This will be fun!!
PM RossViper as he has some experience of this too.
I am not sure it would be terribly hard - the difficulty will be gaining the right protective material...
Good luck
« Reply #3 on: April 11, 2014, 11:04:13 AM »
Buy some skin tight shorts. And shove a couple of copies of the local appear down there.
Sorted
« Reply #4 on: April 11, 2014, 11:17:45 AM »
Am I the only one thinking this is a waste of time??
Just buy one mate, would be easier (and potentially cheaper).
kalph
« Reply #5 on: April 11, 2014, 11:41:35 AM »
I have a set already, this is just something to do to pass time its not that expensive from the calls I've made already
Blazer
  • Team Anti - Concave !.
« Reply #6 on: April 11, 2014, 11:51:00 AM »
1) HD foam / UDHD foam
2) Thin plastic sheet to protect if you are using the HD softer foam.
3) Casing (faux leather type outer and a towel type inner )
4) Straps
5) Velcro
6) Glue , I struggled to find the right one as some types of glue melt the foam.
It depends what you are trying to achieve. If it's a custom fit then you are better off buying a larger thigh pad, get the padding out ,cut it to required shape and put back into the casing.
I have adapted a couple of thigh pads to requirements being a shorty.
tejasapatel
« Reply #7 on: April 11, 2014, 12:05:39 PM »
I enjoy these DIY threads, make me want to do something other than binge shows on Netflix and HBO GO. I learn a lot too.
- Ian Botham
