Author Topic: fibre sheet vs clear sheet  (Read 2171 times)
« on: April 13, 2014, 06:15:44 PM »
Hi guys, had a quick search for this, but what are the pros and cons of both these? I have heard that the fibre sheet reduces performance less? what are the opinions on the forum?
thanks
Jake
Re: fibre sheet vs clear sheet
« Reply #1 on: April 13, 2014, 06:31:52 PM »
Prefer a clear sheet, easier to remove and you can still see the face of the bat.
« Reply #2 on: April 13, 2014, 06:32:51 PM »
I think that the fibre glass is thinner, so weighs less, and therefore preferable in that sense. I suppose if it's thinner then it should have less effect on performance as the barrier between bat and ball is reduced.
However, it is a bugger to remove and looks crap, so the clear, thicker sheets are more appealing to me, as I like how my bats look and I refurb the bats myself.
P.s. The effect on performance is bound to be so marginal though. Hit it in the middle and it'll still go!
« Reply #3 on: April 13, 2014, 06:37:51 PM »
I agree mate, i like a clear sheet, but I was recently told that fibre sheets are good so thought i would ask.
jwebber86
« Reply #4 on: April 13, 2014, 06:44:38 PM »
i use a clear sheet with the reinforced edges.
@james_webber
@dunstercricket
« Reply #5 on: April 13, 2014, 06:56:12 PM »
Marlon Samuels, Chris Gayle and virat kholi use fibre sheets so I'd say there must be something good with them
joeljonno
« Reply #6 on: April 13, 2014, 07:02:30 PM »
They are generally a lot thinner, more flexible and do just as good a job, if not better, than thicker clearer ones.
I use them for my lower grade, already quite ugly, bats. In fact, I prefer them in everything except the look.
What's the point of paying top dollar for a bat to hide the one thing that you really pay for, the looks.
Sent from my iPhone 5S using Tapatalk
Twitter - @joeljonno
« Reply #7 on: April 13, 2014, 07:03:49 PM »
Aaron Finch uses fibre sheets the reason they do is because there lighter and do not mess with balancing issues.
« Reply #8 on: April 13, 2014, 07:48:09 PM »
Loads of the Australians use them.
Clarke, smith, Johnson, Rogers...
tom line
« Reply #9 on: April 13, 2014, 09:44:18 PM »
I have used both the clear ones seem to be thicker and weigh about 2 times as much as fibre sheets and also are easily removed where as the fibre sheets offer much greater less clacking etc and a more permanent solution most likely why pros tend to use them
« Reply #10 on: April 13, 2014, 10:11:35 PM »
Clear sheets have a more negative  affect on performance than fibre and can be better to remove,fibre sheets do not last as long as clear sheets.
« Reply #11 on: April 13, 2014, 10:36:02 PM »
so to summarise,      fibre: better protection, lighter, lesser effect on performance, more flexible and cheaper       whereas----    Clear: look good
thats pretty much it right?
patriotscreen
« Reply #12 on: April 14, 2014, 07:48:47 AM »
Bingo!
Cricklade 2nd XI
Russ
Blank Bats
    • Blank Bats
« Reply #13 on: April 14, 2014, 11:11:27 AM »
the looks dont get you any runs.
if you can get the same job done by adding less weight, then i think its worth it.
Blank Bats
http://www.blankbats.co.uk
« Reply #14 on: April 14, 2014, 11:53:25 AM »
Makes sense. And if you aren't the one refurbing your bat then you don't care how hard it is to remove...
