Lamitoe
Author Topic: Lamitoe  (Read 2628 times)
ajmw89
  • 4XI ornament
    • Wright Cricket
Lamitoe
« on: April 16, 2014, 03:42:17 PM »
Basically, been asked to do this by a friend, but would rather have a go on one of my own bats first.
What is the best wood to use and what's the best way to do it?  I take it a router will be required?
Rob580
Re: Lamitoe
« Reply #1 on: April 16, 2014, 03:51:21 PM »
Junior Hacksaw and some Ikea Chipboard i'd imagine surely?  :D
Fezballoh
Re: Lamitoe
« Reply #2 on: April 17, 2014, 07:13:30 AM »
I think a router would be a pain in the bum unless you've got one of those really small trend ones for doing hinges. Maybe a tenon saw and a steady hand? AS for the timber I've no idea. can't see the harm in using more willow though, Adam. Going perpendicular to the grain will give a ply effect so I'sd imagine it'd be quite strong.
Re: Lamitoe
« Reply #3 on: April 17, 2014, 07:26:31 AM »
it would have to be a hardwood piece - not sure willow would work. i certainly wouldnt do it by hand. it needs to be a nice tight fit as any gaps will be exposed when digging out those yorkers.
BigBlueMachine
Re: Lamitoe
« Reply #4 on: April 17, 2014, 08:01:04 AM »
A milling machine would do the trick. However that seems a bit of an over exuberance just for a lamitoe.
Re: Lamitoe
« Reply #5 on: April 17, 2014, 08:57:58 AM »
The one i made i used a small hand held grinder with  a tiny cutting wheel to cut the slot for the toe i used a piece of oak from an old table top I found at the local tip I first made a template measured and cut into the shape of a protractor shaped the wood with a jigsaw and rasp glued and G clamped  insert into place ensuring a tight fit, after 24 hours finished shaping insert into shape of toe while still clamped.
Re: Lamitoe
« Reply #6 on: April 17, 2014, 09:10:04 AM »
Could you use a piece of carbon for the lamitoe??
Obvioudly only gonns be a small gain. But carbin is very lightweght so could help pick up.
And as ayrtek has proven is bloody strong.
Re: Lamitoe
« Reply #7 on: April 17, 2014, 06:02:52 PM »
I am sure Ryan did a topic on how he did it.
Jaffa
Re: Lamitoe
« Reply #8 on: April 19, 2014, 08:13:04 AM »
Is there any reason why extending the insert to the face of the bat wouldn´t be a good idea?
You´re not looking to knock it over the boundary from the toe, just block. So there is no advantage gained runs wise, just protecting your bat I would of thought.
Re: Lamitoe
« Reply #9 on: April 19, 2014, 08:47:52 AM »
Purely that it isn't allowed under the laws. I'm not sure whether it would also be weaker in terms of crack propagation.
Jaffa
Re: Lamitoe
« Reply #10 on: April 19, 2014, 11:48:05 AM »
I´m not up to date on the laws saying how a bat should be made. I hope someone could quote something relevant.
It´s just the apart from the edges, the cracks in the toe I get are from digging out yorkers are parallel to the face, in few mm´s in. I doubt a lamitoe would help.
Ryan
  • Trade Count: (+17)
Re: Lamitoe
« Reply #11 on: April 21, 2014, 03:06:14 PM »
I did Nick, link below
http://custombats.co.uk/cbforum/index.php?topic=21249.msg340747#msg340747
I actually use a biscuit jointer these days, it's easier and quicker.
