Author Topic: knee support wraparounds advice needed  (Read 1035 times)
The Palmist
  • Trade Count: (+15)
« on: May 19, 2014, 11:02:48 AM »
Hi All
I keep hurting or bruising my knees in the ground. Any recommendations on support bandages or wrap arounds?
I have seen some neoprene stuff at boots but not sure if they are any good.
Re: knee support wraparounds advice needed
« Reply #1 on: May 19, 2014, 11:08:00 AM »
Tubigrip is prob the best option if its as a preventative measure to avoid grass burns/bruises etc.
Neoprene ones are ok if your looking for actual support to the knee but can get a bit restrictive if you dont get one the right size and are quite warm to wear.
« Reply #2 on: May 19, 2014, 11:08:10 AM »
I wear knee supports when fielding on hard ground the ones I have have a one inch hole in the middle of the kneecap to release pressure when bending down.
fasteddie
  • Straight up.
« Reply #3 on: May 19, 2014, 11:43:38 AM »
Having anything directly over the patella compressing it is a bad idea.
What you are doing is increasing wear to the joint by a factor of the compression applied.
Have you tried Skins? I wear them and it serves to do that job without causing pressure on the joint. They aren't cheap, but mine are 4 or 5 years old and still going strong.
The Palmist
« Reply #4 on: May 19, 2014, 02:56:50 PM »
what about the ones with hole as mentioned by Seniorplayer?
I have tried skins but I get too warm in them, tried both cool and hot versions. May be I will chop the legs off and use it just on knees.
