Author Topic: Can she be saved?  (Read 1606 times)
Can she be saved?
« on: June 05, 2014, 07:22:40 PM »
#Heartbreak
Strange split, further down the back than the front.
Can she be saved??
Let me know that you think please  :(
simonmay5
Re: Can she be saved?
« Reply #1 on: June 05, 2014, 07:32:57 PM »
A bit off glue and a couple off dowels she be as good as new
« Reply #2 on: June 05, 2014, 07:41:58 PM »
Not a fan of doweling me find it creates a more weak-spot rather than strength
« Reply #3 on: June 05, 2014, 07:43:43 PM »
A little crack like that doesn't need dowelling.
Send it to me and i can sort it mate ;)
« Reply #4 on: June 05, 2014, 07:57:22 PM »
Hi Cam, I PM d you re this
« Reply #5 on: June 05, 2014, 08:01:54 PM »
Hi everyone
Thanks for the advice and offers.
I have opened up the crack and there's no way I'm dowelling it!
It was actually 2 cracks, one down the edge and the one you can see.
I was effectively left with 3 openings, these have been filled with PVA (not watered down as I wanted it full strength) and I've wrapped tightly with tape to clamp it.
Fingers crossed this has saved her, if not, she went like a gun while she was alive, shame I didn't get as much use as if have liked.
Will update on Sunday when I'll take the tape off!
« Reply #6 on: June 05, 2014, 08:48:47 PM »
And so people know what I mean by the split, I've used my iPhone for some high quality editing to show where the crack ended up when I opened it up.
It split in two places effectively
At the base of the red line you can see where the crack continues, this opened all the way to the base of the crack
Let's hope the glue worked, a bit of tape and hopefully she'll be good as new.
Perkins17
    • GM Cricket
« Reply #7 on: June 05, 2014, 08:49:44 PM »
I would also have an insert put in as it will help stop the crack from growing and put a larger amount of strength back in the toe which a doweling wouldn't do, how come you are leaving it taped up till sunday? the glue will be dry by tomorrow
« Reply #8 on: June 05, 2014, 08:52:34 PM »
At work all day tomorrow and leaving early Saturday so won't have time to finish the job, might as well do it properly rather than rush things.
sarg
    • CricketBatInfo
« Reply #9 on: June 05, 2014, 10:42:08 PM »
What does an insert look like? Just interested as I have seen picks of doweling a crack, but not this method of repair?
