Author Topic: Sound of De-lamination vs Butterfly stain  (Read 1090 times)
joeljonno
« on: June 26, 2014, 11:19:07 AM »
Hi guys
I am looking at a bat that has been recently bought 2nd hand by someone, used very lightly prior to purchase and is about 3 months old.
I have tapped it up with a mallet and there is a rasp/rattle in part of the blade, around a small butterfly stain.  I have spoken to one person on here who I trust and says that the sound I have described is probably due to the slightly harder nature of that bit of the bat.  The bat performs really well and I 100% trust the guy I have spoken to, so I am not overly worried, but I thought I would check with you lot,
As I have never had a butterfly stain on the bat, so my question is ...
"Could a butterfly stain potential sound similar to a de-laminating bat when using a wooden mallet?"
Thanks in advance
Joel
Twitter - @joeljonno
Re: Sound of De-lamination vs Butterfly stain
« Reply #1 on: June 26, 2014, 12:17:58 PM »
I think so - I have had bats with "hard bars", and there is a notable difference in the sound coming from that part of the bat.
WillyorWonty
« Reply #2 on: June 27, 2014, 10:58:18 AM »
Despite what B3 says a knot running across the face is harder and cannot offer the same spring as clean wood. If the bat has a higher tone then it would be harder, if it has a double tap or hollow ring then it will be delaminated.
« Reply #3 on: June 27, 2014, 07:01:45 PM »
Regarding  Butterfly stains because there's less sap they are naturally harder which can produce a different contact sound which as previously stated is an higher tone.
« Last Edit: June 27, 2014, 09:39:17 PM by Seniorplayer »
« Reply #4 on: June 27, 2014, 07:07:14 PM »
I've just picked up 2 butterflies from b3 for team mates.
One has a predominant butterfly in the playing area. With a mall it sounds awful. And you instantly aren't filled with confidence.
But drop a ball on it and it rebounds phenomenally.
You just got to get used to the sound and any negative thoughts out of your head.
« Reply #5 on: June 27, 2014, 07:10:13 PM »
Sound and performance two very different things
