Author Topic: Pittards across brands.  (Read 3835 times)
Uniquedan90
« on: July 07, 2014, 06:19:52 PM »
Are there differences between pittard palms across brands ? If so what are the differences and which brand would forum members suggest ?
Thanks in advance for input.
Top innings: 154, 120, 109, 108, 80
Best bowling figures: 6 - 38, 4 - 25, 3 - 25, 3 - 16, 2 - 18
Nickauger
Re: Pittards across brands.
« Reply #1 on: July 07, 2014, 06:36:12 PM »
Pittards is the brand mate! if it says Pittards, it should all be the same!
Uniquedan90
« Reply #2 on: July 07, 2014, 06:40:37 PM »
Ahhhhh ok Thanks NickAuger, I just for example see Cougar Pittard Palms or just Standard Pittard listed with nothing infront so wasn't sure on differences.
Tom
    • www.cricketinsight.co.uk
« Reply #3 on: July 07, 2014, 08:20:16 PM »
Pittards is the brand. The types are the cuts/treatments applied to the leather. Cougar is the standard leather with the WR100x treatment. A few brands use Armortan with the digital pattern.
Most brands though these days just use the standard Cougar leather.
praguetaz
  • Royal Vinohrady CC
« Reply #4 on: July 07, 2014, 08:21:18 PM »
I got some H4L NV pittard gloves recently... beautifully soft, greyish in colour so looking forward to playing in them at the weekend.. feel great on their grips too.
Had Bellingham and Smith LE pittards too which were also great quality.. hardened a little over time and use...
Pittards I believe give better grip with the pattern especially over soft, smooth leathers so would recommend them and as the previous forum member said they are always labelled 'pittard'.
Uniquedan90
« Reply #5 on: July 07, 2014, 08:25:49 PM »
Thanks for the info Tom & PragueTaz, That's what I was confused about the leather cuts and treatments as you described much easier to ask here than research trawling through the net,
I'll take a look at the H4L ones too any other suggestions on brands etc would be much appreciated also from both mainstream brands to forum brands etc
« Reply #6 on: July 07, 2014, 11:03:36 PM »
To be fair, all leather palms harden over time thanks to sweating, but most of us on here don't keep gloves long enough to find this out.
praguetaz
« Reply #7 on: July 07, 2014, 11:25:58 PM »
check out 'blank bat' pittards too... there may still be some limited edition ones available...
other highly recommended but expensive options include:
newbery sps 1
salix pod players
H4L nv pittards are 50 gbp posted from vitas sports... cheapest deal by far for top quality...
smokem
« Reply #8 on: July 08, 2014, 01:37:28 AM »
I find the grey diamond pattern Pittards don't harden up at all. I have a pair of gloves with this and it's still as soft as new after using them for 1.5 seasons. They tend to be thinner, which doesn't affect durability but just feels thinner when gripping.
The white Pittards with the small holes do tend to still harden up. They feel a little thicker in the hand as well.
Uniquedan90
« Reply #9 on: July 08, 2014, 07:25:04 AM »
That's my issue currently I'm going through gloves quite quickly as I've just got used to the same glove and kept reordering them but thought it's time to make a change, I'll be sure to look at blank bats & H4L, I like the Newbery style very minimalist, I'd seen black Pittard palms somewhere anybody used those ?
Nickauger
« Reply #10 on: July 08, 2014, 07:44:49 AM »
Bulldog Spirits will be around that sort of price too! If you're lucky, Kieron might have some last years stock kicking around, and there's some serious discount to be had normally then!
WillyorWonty
« Reply #11 on: July 08, 2014, 08:48:22 AM »
Does anyone know what kind of Pittards these are? I want some but dont like the grey stuff, like the ones with the holes in.
http://onlinestockist.com/SM-Swagger-Pittards-Batting-Gloves-P1239374.aspx
cricketrob
« Reply #12 on: July 11, 2014, 02:16:50 PM »
I've had various gloves with pittard palms and they all seem to have the same amount of grip and feel. A pair of duck and runs I had did dry out very quickly however which was annoying as they were previously very comfortable.
Uniquedan90
« Reply #13 on: July 11, 2014, 02:26:21 PM »
I'd looked those Duck & Run ones too so cheers for the heads up.
kal_m
« Reply #14 on: July 11, 2014, 04:59:32 PM »
I got the SS Millenium Pro Pittards and they are really good too.
Aspire and Achieve
