Thinnest batting pads
Author Topic: Thinnest batting pads  (Read 4598 times)
Akewstick
« on: July 18, 2014, 10:20:38 AM »
What are some thin batting pads?
My pads are too big, they're too bulky, in fact in terms of height they're slightly too small but that doesn't bother me as much as them being about 4 inches thick from your knee to the outisde of the knee roll, I need THIN pads.
I'm wearing Ihsan ones at the moment just because I stumbled across top of the range ones for £20 so they got snapped up, but tapping my bat at the crease I'm having to consciously avoid getting my gloves/handle caught on my pads, it can't be helping me play straight.
Also, the protection on the Ihsan pads is ridiculously good, as in so good it's just unecessary, you get a rapid full toss straight onto your pads and literally can't feel it touch you. I'm prepared to sacrifice a lot of protection to get some thinner ones but annoyingly, it's not something anywhere on the internet mentions.
    • Neon Cricket
Re: Thinnest batting pads
« Reply #1 on: July 18, 2014, 10:33:36 AM »
I'd guess the Morrant pads would cover this - expensive mind
Pretty sure some of the cheaper pads from the big companies would be thinner, mainly because the increased padding wouldn't be there
    • Neon Cricket
« Reply #4 on: July 18, 2014, 11:27:43 AM »
Good Lord!!
and the RRP is £120 too!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #5 on: July 18, 2014, 11:30:19 AM »
Hmmm, well I quite llike them.... :o !
parthnayak
« Reply #6 on: July 18, 2014, 12:10:32 PM »
from what I have used, SS/Ton Gladiator and Puma Platinum 5000 i.e. they provide the best of both worlds, protection and fit,  I can vouch for puma pads.
« Last Edit: July 18, 2014, 12:18:43 PM by parthnayak »
« Reply #7 on: July 18, 2014, 01:12:20 PM »
Sports direct do some fabric faced Fernley ones, very thin and no danger they'll offer any "unnecessary protection"  ;)
joeljonno
« Reply #8 on: July 18, 2014, 01:25:20 PM »
But you will need to wear two pairs on top of each other.
Twitter - @joeljonno
JB
« Reply #9 on: July 18, 2014, 01:26:39 PM »
I've got a set of M&H T2's, they have a set of removable shin guards for use in the field. If you take them out you are simply left with the pad which is feather light, I use them in the nets all of the time with no problem at all.
Akewstick
« Reply #10 on: July 25, 2014, 10:56:52 AM »
Those look perfect but...
do you spend £100 on pads?
Do you live in a castle?
jwebber86
« Reply #12 on: July 25, 2014, 02:55:02 PM »
i agree i think they look quite good
just had an email from m&h the t1 softs are reduced pads are £60 and gloves are £48
« Last Edit: July 25, 2014, 03:03:09 PM by jwebber86 »
@james_webber
@dunstercricket
eukaryote76
« Reply #13 on: August 06, 2014, 12:18:10 AM »
I might try the M&H if they were reduced, but can recommend VKS Superlites at Under £40- you may need to adjust the straps though. I've not long done a review in the VKS section.
