Batting Master Class videos
Pages: 1 2 3 [4] 5 6
Author Topic: Batting Master Class videos  (Read 110240 times)
Calzehbhoy
Re: Batting Master Class videos
« Reply #45 on: April 23, 2018, 09:14:53 PM »
Another video with KP https://www.youtube.com/watch?v=yrLUd99fqWc
Not interested in how, it’s how many!
Love that!!
« Reply #46 on: April 24, 2018, 12:24:19 AM »
I want KP to be my coach. :D
golders
« Reply #47 on: April 24, 2018, 06:36:28 AM »
" I kept things very very simple"hehe
Duck Duck Mongoose
« Reply #48 on: August 05, 2018, 07:24:50 AM »
There were a load of AB de Villiers masterclasses on his cricketyard website, similar to this one on youtube: https://www.youtube.com/watch?v=Nrzz4sYGSVM
There was a great one about the ramp shot that I've been searching for but cricketyard.com is now defunct and I can't find it on youtube.
Any ideas?
« Reply #49 on: September 15, 2019, 07:54:35 AM »
This is Steve Waugh and it is probably one of the best of these I have seen. Also I was at the SCG when he scored that last ball ton.
So much good stuff in this.
https://www.skysports.com/cricket/news/12123/11809568/steve-waugh-masterclass-former-australia-captain-on-the-art-of-test-batting-and-his-supreme-career
ppccopener
« Reply #50 on: September 15, 2019, 11:12:54 AM »
Thanks for posting, very good.
Much admired even thou he scored so many against us.
The small step movement just to transfer weight maybe something a few of us have worked on
« Reply #51 on: May 20, 2021, 09:12:03 PM »
https://youtu.be/ehWkuHa2Jkw
Athers, Hussain and Butch talking batting guards and head position.
Yes please.
Nate
« Reply #52 on: May 21, 2021, 12:18:42 AM »
Cracking watch that Buzz, would be interesting to see if the modes of dismissal have actually changed that much given the change in technique.
SouthpawMark
« Reply #53 on: May 21, 2021, 12:49:58 PM »
Yes please.
Really good video. Poor old Sam Robson must wonder what he’s done to those three to have his technique ripped to shreds on national telly, but it’s a great discussion on a really questionable technique.
Bat perv.
« Reply #54 on: May 21, 2021, 01:07:29 PM »
Buzz already knows my thoughts on this video.
But batting on off stump is not in itself a questionable technique.
Robsons problem is that his head falls over and so he misses straight balls.
Shane Watson did this and batted on leg stump but was out LBW More than any other dismissal.
Your guard is categorically not the reason you are getting LBW, your head almost definitely is.
Batting on off stump doesn’t change your head, and neither does batting on leg stump.
As for Butcher saying that this technique “is just wrong” I wonder if he is aware that the only 2 players to average over 60 in test cricket in the last decade currently adopt this approach.
Kane Williamson - who most regard as the most technically adept player on the circuit, bats outside off stump!
If your fundamentals aren’t in check, you will get out wherever you bat. All that video shows is that more county batsman nowadays don’t play straight because they fall over, and don’t have their fundamentals in check.
ppccopener
« Reply #55 on: May 21, 2021, 01:07:51 PM »
Totally agree, if there are so many batsmen using this technique(there clearly are) then use 4 or 5 different ones not just Robson.
I'm firmly against following the MCC rule out as a Bible, but there are some basics you must do if your going to score runs, how you stand,backlift,head position all key.
If your standing on off as a right hander I can't see how you can hit straight without your bat coming from gully across the ball....clearly the players using this can do, it just seems flawed.
I thought Butch was blowing a gasket at one point  :)
« Reply #56 on: May 21, 2021, 01:08:41 PM »
Your guard is categorically not the reason you are getting LBW, your head almost definitely is. Your guard also doesn’t change your head alignment in relation to your body.
« Last Edit: May 21, 2021, 01:11:41 PM by LEACHY48 »
« Reply #57 on: May 21, 2021, 01:11:15 PM »
You hit straight the same way you would if your batting on leg? The shot doesn’t change.
ppccopener
« Reply #58 on: May 21, 2021, 01:18:55 PM »
Ok...where’s you head thou in the stance. If your on off isn’t your head naturally going to be outside off stump?
Or have I missed something?
« Reply #59 on: May 21, 2021, 01:36:38 PM »
No, I stand with my right eye over my back leg (right handed) so wherever my back leg goes, my right eye stays over my back leg.
If you stand on leg with your eyes over off you’re already losing the battle?
It’s nigh on impossible to pick your head back up after it starts to fall over, and if your head is outside the line of your body then you’re already in the mire!
So, if I stand on off, my right eye stays on off, and my left eye and foot are on middle/middle and off.
