the stuart broad incident
Pages: 1 ... 20 21 [22] 23 24 ... 31
Author Topic: the stuart broad incident  (Read 111893 times)
Montys Beard
Re: the stuart broad incident
« Reply #315 on: August 19, 2014, 12:04:46 AM »
We're famous!
https://www.facebook.com/lekkaww/posts/10204621464205410
Personally after being hit on the grill twice with my Ayrtek I wouldn't look elsewhere - yes this incident is unfortunate but hopefully Tom will be able to bounce back from this and get Broad back in an Ayrtek for the next series, I've tried on the double bar Masuri and seriously can't understand why someone would choose it over an Ayrtek - the vision and weight is awful compared!
Yep, he's mentioned the forum three times in as many days, including a wonderfully cryptic message to us all....
"The aim of English cricket is, in fact, mainly to beat Australia" - Jim Laker
@LiamGarratt
plumb111
  • High Score 110* Bowling - 6/22
« Reply #316 on: August 19, 2014, 08:26:09 AM »
whats his issue ? Surely he would be better off trying to make friends with people on here instead of mouthing off about cbf members ?
clearly gutted everyones not snapping up his equipment
Why do we put ourselves through it ?
The Palmist
  • Trade Count: (+15)
« Reply #317 on: August 19, 2014, 08:27:36 AM »
errm talk about yourself mate, he clearly says "Most" and not "All"
JK  :D :D :D
Cowcorner
« Reply #318 on: August 19, 2014, 09:48:11 PM »
Chad,  there is another setting where the ball can get through.  On the bottom row of holes,  second hole from the back.  Nick's helmet at the cbf day was set like this and we noticed that the gap was big enough for a ball to get through.
Surely all three of the bottom holes will let the ball through - if not then the one to the right definitely will, if the centre one does. I hope that's made sense?
I might have to try all the settings on my Ayrtek to see if that's correct, unless somebody else already has?
« Reply #319 on: August 19, 2014, 10:06:58 PM »
It's not quite that straightforward. I use the rearmost hole on the bottom in that picture and there is no way the ball is getting through. The shape of the front mount is such that you get a variation on gap size as it isn't a flat line.
TangoWhiskey
  • Review that.
Optical
« Reply #322 on: August 20, 2014, 09:05:01 AM »
It was 'deal of the day' yesterday @ £45. Gone back up now.
TangoWhiskey
  • Review that.
« Reply #323 on: August 20, 2014, 09:06:24 AM »
Oh, fair enough!
« Reply #324 on: August 20, 2014, 09:08:52 AM »
That confused me as well! £10 off!  :(
But £45 would be a bargain!
« Reply #325 on: August 20, 2014, 09:19:00 AM »
Well we learn something new everyday. Deal of the Day lasts until the following morning when somebody gets into the office and changes it  :D - and probably starts at the same time!
TangoWhiskey
  • Review that.
« Reply #326 on: September 07, 2014, 08:06:31 PM »
Did I miss the press release about this? Has anything been said?
mattcoll12491
« Reply #327 on: September 07, 2014, 10:36:53 PM »
Left-Arm Curious
TangoWhiskey
  • Review that.
« Reply #328 on: September 08, 2014, 08:10:36 AM »
http://www.ayrtek.com/stuart-broad-injury-press-release/
That's not an explanation for what happened though. I want to know the results of the finding. Was it just an already damaged helmet or did the top edge expose a flaw which was previously untested?
« Reply #329 on: September 08, 2014, 08:27:27 AM »
Disclaimer: This is not an Ayrtek explanation, and is purely anecdotal
If you look at one of the other pages in this topic, we discovered that on certain settings of the grille, the gap is such that the ball can fit through between the peak and the grille relatively easily (i.e. you can push it through by hand). Looking at the settings that Broad was using (in the pictures of the event), it looks like this is what happened. This also is the widest gap in terms of vision, that the Ayrtek settings allow. You can see the result in the first picture below, and also an indication of another setting where we found the gap large enough for the ball to pass through in the second picture.
and
« Last Edit: September 08, 2014, 08:29:01 AM by tim2000s »
