Author Topic: felling a willow tree  (Read 13198 times)
« on: November 04, 2014, 10:23:39 AM »
I am looking at having some trees prunned in my estate (small garden) and one of the things that has come up is the time of year the trees have to be pruned - i.e. usually in the autumn/winter when the sap is falling - and not in the spring summer when the sap is rising (not always the case but you can see where this is going)
is there an optimum time of year to fell a willow tree? would cutting it down in the autumn for example lead to lower sap content in the willow, for example? is the sap content in the spring higher and will this impact the clefts as the wood is growing faster?
Does the drying process take this all out of the equation?
Does anyone actually know much about trees and willow trees?!!!
KIPPERS
Re: felling a willow tree
« Reply #1 on: November 04, 2014, 10:41:03 AM »
Growing your own Bats. Now that is impressive
Bambooman
« Reply #2 on: November 04, 2014, 11:06:48 AM »
I don't know this for sure but a friend of mine cuts trees for GN. I remember him saying in the past that the best time is just before spring when sap is at it's lowest. Apparently it makes the wood less likely to split whilst drying. Having said that though a crop of 20 willows has just been cut down up river from me by a neighbour. I think JS Wright came to do the harvesting.
I would call Mr Ruggles to get a definitive answer though.
TheBiologist
« Reply #3 on: July 06, 2015, 04:30:41 PM »
I am a researcher in plant metabolism and can tell you a bit about the biology of the "sap movement". Essentially the tree is trying to move the nitrogen contained in the leaves to the bark for storage (as a protein called bark storage protein) through phloem right before winter, else it will be lost with the falling leaves in winter. Nitrogen in THE limiting nutrient for tree growth. And in spring the nitrogen stored in winter is broken down and sent to the shoots via xylem so that the tree can create leaves and carry out photosynthesis.
The soil in general is much drier in the winter than in spring and summer, however it could vary depending upon the location. And the transport by xylem MIGHT require more sap since it is flowing higher up the tree to support growth of shoots and leaves. Major chuck of the leaves is water, so a bit more sap in spring is likely. However, this is probably going to be discernible only in small branches not in the main trunk of the tree.
I am not 100% sure, but IMHO a woody tree is unlikely to have huge variations in moisture content between spring and winter. If I were you I would cut it in winter!
« Reply #4 on: July 06, 2015, 04:34:54 PM »
I was taught at school that sap rises in the spring.
« Reply #5 on: July 06, 2015, 07:11:59 PM »
Thanks @TheBiologist , given willow sets are usually planted on flood planes/wet lands, would that make a difference?
I would say they were in wetter lands during winter.
TheBiologist
« Reply #6 on: July 06, 2015, 07:48:45 PM »
Well, most trees have robust mechanisms for resisting water stress. Trees that grow in wetlands in general are hardwoods. They resist the increased water by producing more lignin which makes the wood hard and resistant to infections. I doubt the moisture content in the wood will be drastically high. Although I cannot say with certainty (no experience in willow or forestry, just metabolism), my guess is the winter in water probably makes the willow a bit stronger. Taking my words back here, it makes sense to harvest it in late Spring.
