Pages: 1 ... 16 17 [18] 19
Author Topic: The Winter Bat Refurb Thread  (Read 94352 times)
ppccopener
Re: The Winter Bat Refurb Thread
« Reply #255 on: May 05, 2017, 09:13:44 AM »
tom im going to whatsapp you about my mates bat.
Don't need you to do anything just want a second opinion....it's my mate's Amplus and been repaired once now gone again(this time thru the back of the toe.
My mate absolutely loves this bat
i'll send you a photo..
all the best
« Reply #256 on: May 05, 2017, 11:58:57 AM »
Question: applying a scuff to a mongoose mmi3. Should I cover the whole of the front sticker or should I cut it shorter like a standard bat?
tom line
« Reply #257 on: May 05, 2017, 12:12:40 PM »
I'd say whole bat face as the whole face will be used and help protect the stickers
« Reply #258 on: May 05, 2017, 12:27:12 PM »
Thanks, that's what I thought, I was just concerned it may look a bit weird.
« Reply #259 on: May 07, 2017, 09:32:04 AM »
Bought these off here.
One had very minor surface cracks which were easily repaired. The other had slightly more extensive delamination. After a bit of surgery it is not all glued and solid.
All completed and stickered. I will scuff the one on the left but leave the one on the right in case I need access to glue down any further delamination.
« Last Edit: June 29, 2017, 06:55:58 PM by Gurujames »
tom line
« Reply #260 on: May 07, 2017, 09:46:16 AM »
Top work on those @Gurujames
Always find trying to get all the delam a challenge as can sometimes take several glueing sessions
« Reply #261 on: May 07, 2017, 09:58:00 AM »
A combination of needles, syringes, Stanley knives and butter knives did the trick. The delamination was in a fairly localised area so I was able to get to it in one go. However, it may well spread, that's why I won't put a scuff sheet on.
« Reply #262 on: May 07, 2017, 06:07:57 PM »
Great post @Gurujames
Calzehbhoy
« Reply #263 on: May 08, 2017, 08:07:02 AM »
Two cracking sticks for the money there mate! Hope they go well!
calcurtis98
« Reply #264 on: May 10, 2017, 07:14:38 AM »
Piggy banking onto this post again - apologies.
How bad is feathering of the toe and also some small (compress maybe) cracks near the toe?
Can get picture when I am home from work later if it helps!
Batting - 61 & Bowling - 6/15
langer17
« Reply #265 on: May 10, 2017, 07:43:48 AM »
Feathering isn't bad at all. Happened to my main bat 4 years ago but some watery super glue down there and never had an issue since
velvetsky01
« Reply #266 on: May 10, 2017, 08:07:32 AM »
Yeah two great looking bats
HS: 119*
Best Bowling 7.4-1-32-6
« Reply #267 on: May 14, 2017, 08:16:00 PM »
Little refurb on my SS as the inside edge had split and it started delaminating :(
« Reply #268 on: May 16, 2017, 03:16:47 PM »
@Gurujames where did you get those spiral grips from mate?
