Author Topic: Linseed substitutes  (Read 1724 times)
Bambooman
Linseed substitutes
« on: November 25, 2014, 08:58:08 PM »
The other week I remember reading a thread where someone had used olive oil to treat a bat they had refurbed (sorry can't find it). I remember the idea of olive oil not sitting right in my mind so I decided to look into it and found this information from a woodworking site.
"...Oils can be separated into those which cure or set and those which always stay liquid. The ones which set are best partly because a cured oil protects the wood better, waterproofing the surface and not washing out, but also because an oil that always stays liquid like olive for instance can go rancid.
The three most common oils which set on their own are linseed, walnut and tung oil. Linseed and walnut have both been used as the carrier oil in oil paintings from the middle ages and it is the oil curing which sets the paint. Tung oil, made from a tropical nut, is commonly used in commercial finished like danish oil which is basically a mix of tung oil (expensive) with white spirit (cheap) the white spirit makes the oil thinner and helps it penetrate the wood. Warming the oil has the same effect but without adding unpleasant chemicals. "
So it turns out that olive oil is not a great idea but walnut oil might be if you require an emergency oiling and are caught short.
KIPPERS
Re: Linseed substitutes
« Reply #1 on: November 25, 2014, 10:05:55 PM »
well you should never really run out unless your daft enough to buy tiny bottles off cricket companies with pretty labels.
Boondougal
« Reply #2 on: November 26, 2014, 10:21:03 PM »
oops, that will be me then!
I literally could not have put less on but it does appear to have not been advisable based on what you have found.
I'm pretty sure it will be fine but i guess its not an ideal option.
KIPPERS
« Reply #3 on: November 26, 2014, 10:50:22 PM »
doubt if it will do any harm
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #4 on: November 27, 2014, 01:25:17 PM »
Mineral oil is a well used, water repellent finish in woodworking.  Could proabably also use Danish or Tung oil
KIPPERS
« Reply #5 on: November 27, 2014, 01:56:29 PM »
Danish oil is a very common finishing oil in the furniture trade and with things like high end audio speakers. But does it smell as good?
