Author Topic: Woodworm torch refurb project  (Read 2162 times)
« on: December 20, 2014, 12:19:56 PM »
Hi guys
You may have seen the first post on this bat, but incase you haven't
http://custombats.co.uk/cbforum/index.php?topic=32919.msg518287#msg518287
All the before pictures are in that thread, so to avoid an overload and double posting I won't put them all again.
This is how the bat arrived. A bit or tape and a few cracks here and there.
The first thing I did was glue a crack in the shoulder, this was almost a right angle going 3/4 of the way through, so needed some attention.
Once that glue had dried I gave the face and edges of the bat a good sand down.
As the back was in pretty good condition I only gave that a very light sand so the finishing was consistently smooth all over the bat, I didn't take a picture as it looks the same as when I started!
And where I'm up to. Currently waiting for the glue to dry on all the face cracks.
Once dry I will give the face and edges one last fine sanding, then apply some oil.
The plan is to eventually get the bat scuffed up and ready to use, and as I am off work between now and new year I should hopefully get this done before the end of the break.
Re: Woodworm torch refurb project
« Reply #1 on: December 20, 2014, 01:20:24 PM »
Excess glue removed
And shoe goo applied to the toe
Once the Shoe Goo is set, I'll give the face and edges a final sand before oiling
i12breakfree
« Reply #2 on: December 20, 2014, 01:36:01 PM »
That looks nice. Once done with cleanup apply a quality face sheet to prevent any further damage. How does it ping ?
« Reply #3 on: December 20, 2014, 02:06:35 PM »
That was the plan bud. Trying to decide between a fibreglass one for authenticity (there was factory fitted on mine) or a clear GM style one.
And the Ping is good when I tapped a ball up with it. Hopefully plenty of life left in it now all the cracks have been dealt with  :)
« Reply #4 on: December 20, 2014, 10:31:58 PM »
The project became one day's work in the garage.
She cleaned up alright, if I do say so myself  :D
