repairable??
Author Topic: repairable??  (Read 1324 times)
repairable??
« on: January 17, 2015, 06:00:11 PM »
The skippers bat
square cutting Metal stumps not advised!  What's course off action is advised to repair? If repairable.
Re: repairable??
« Reply #1 on: January 17, 2015, 06:36:44 PM »
Depends on if the wood has been cut out or squashed a little. Maybe able to glue back on ok or may leave a small hole depending on the state of the cut. Happy to take a look for you mate if you wish.
Bambooman
Re: repairable??
« Reply #2 on: January 17, 2015, 06:56:52 PM »
I've repaired similar damage using pre-pressed willow plugs. The hardest bit is getting a grain and colour match for the plug.
Re: repairable??
« Reply #3 on: January 17, 2015, 10:08:07 PM »
I did exactly the same with a brand new £ 200.00 GN went  back over the metal  stumps in the nets playing a late cut and took a chunk out repaired mine with a mixture of glue and wood filler only used  it for a couple of innings after repair  as was always conscious of it during batting ended up putting it in the club kit bag
Re: repairable??
« Reply #4 on: January 17, 2015, 10:11:55 PM »
Get the scuff sheet off, glue the piece back in, use a mallet to get it in there as best you can, give it a sand so its level, strip of tape and new scuff sheet. Job done (I may be being slightly optimistic!)  ;)
