Author Topic: Do I need to remove fibreglass tape to oil my bat?  (Read 3633 times)
Akewstick
« on: January 23, 2015, 10:47:33 PM »
At the end of my very first season after taking up cricket from scratch at the age of 23 I managed to pick up a H4L hattori for 160 squid and for some reason covered the face in fibreglass tape (because other people did it) and after one season of play it's still in lovely condition but probably needs an oil.
1.) Do I need to remove the fibreglass tape to oil it?
2.) How do I get the tape off?
pikey
Re: Do I need to remove fibreglass tape to oil my bat?
« Reply #1 on: January 24, 2015, 12:51:54 AM »
Yes and No
The fibreglass does the same job as oiling the bat i.e. retains the moisture content of the willow, but with the added bonus of adding some extra protection.
Personally, I would recommend changing the fibreglass sheet/tape once a year, but you can leave it on if you wish.
I change mine because there may be some damage underneath the fibreglass that you cannot see. When damage is treated early, it can save your bat.
Secondly, the fibre glass sheet/tape can cause delamination of the bats face if left on for too long.
If your not too worried about the bat and you don't want the trouble of taking the tape off, just give the exposed wood on the bat a quick rub down with sand paper and a light coat of oil. If however you do want to tackle taking the tape off, you can cut along the edge with a Sharpe knife then heat up the tape with a hairdryer for around 2-3 minutes (loosens the glue) and then gently peel it off.
I usually take mine off at the end of the season, give the bat a light sand and oil and then reapply a sheet at the start of the season.
*you will get a much better finish if you use a scuff sheet on the face instead of tape and just use the tape to reinforce the edges and toe :)
As with most things in cricket I'm sure other people will have their own theories and opinions.
