Pages: 1 2 [3]
Author Topic: CA U-AK3 Cricket Bat. My new bat!  (Read 13717 times)
Re: CA U-AK3 Cricket Bat. My new bat!
« Reply #30 on: March 01, 2015, 06:45:42 PM »
Just tried the spit and steam trick, worked a treat.  Thanks for the tip Dave.
@Wooly
Super!
Can you share the exact steps/process that you followed? Thanks.
« Reply #31 on: March 01, 2015, 06:47:25 PM »
Any time mate glad it worked
I will do a video it is easy for small dinks you spit in the area and as your kettle boils place it over the kettle the effected area
I would love to take credit for it but it was Streaky showing me
« Reply #32 on: March 01, 2015, 06:48:45 PM »
Awesome!
abdulwq
« Reply #33 on: March 10, 2015, 11:07:09 PM »
How much you paid for it?
Does this spit n steam would work to swell up the whole bat? just curious to know if thats how huge profiles are being made in smaller weights.
« Reply #34 on: March 10, 2015, 11:09:04 PM »
Never tried but no it would dry and split the bat mate on contact only for small dinks and i mean really small
KIPPERS
« Reply #35 on: March 11, 2015, 01:24:03 AM »
Im an old fuddy duddy i think it looks like a floorboard
« Reply #36 on: March 11, 2015, 02:45:31 AM »
Very nice, the profile seem to be exactly like what he is currently using unless I am being deceived.
What is edge size if I may ask?
Hope this bat serves you well, looks VERY impressive. The new livery is big improvement.
amritpremi
« Reply #37 on: March 11, 2015, 04:18:32 AM »
One day I saw Akmal using this higher middle and another day mid/low one. I think he is changing the bat a bit too often unless my eyes have been decieving me.
kvskpin
« Reply #38 on: September 12, 2017, 04:20:59 AM »
Well, This is my take in this and I did some experiments on my SS Gladiator and MRF Grand Edition to test out. I have to say that I was very cautious considering the sheer quality of bats that was at stake.
A bit of science:
1. Trees suck up water along the direction of the grains and not perpendicular to them. This is the reason why the toe of a bat is the most vulnerable in addition to the fact that it is exposed more to the factors such as dampness of the ground. It is also subject to most of the abuse (apart from the middle of the bat that is). That is not to say that if you have a splash in the middle of your bat, you should not be worried. Timber being a porous material, that splash may prove costly and spills should be wiped off immediately. I had a BAS Vampire Grade 2 Willow bat, with which I played on damp ground and trust me, it had some serious swelling near the toe. That bat was later machine rolled and turned into a beautiful tennis ball bat.
2. Steam - We all know that water is harmful for a bat. But then, steam is a different proposition. The reason for the same is how much of steam? 10 grams of water when converted to 10 grams of steam, is actually, a hell of a lot of steam. If I expose my bat to a jet of steam from a steam cleaner for a minute, that is equivalent of 10 grams of water at the best (approx). Out of that 10 grams of steam, most of it is going to fly off. At the best a gram of it is what would condensate on the bat. If one is careful about wiping it off immediately, a good amount of it gets into the towel, leaving about 0.1 of a gram of water. That is a rough, back of a tissue paper calculation. Having said that, steam is hot and it is the heat that is damaging. Prolonged exposure would cause damage to the wood. So, short bursts of steam of up to 10 sec and up to 5 times with 5 minutes break in between, shouldn't be a concern.
Finally, it is about time to put theory to practice. As I said, what is at stakes are two beautiful blades that have been bowlers envy, but also have enough dings of various sizes on the face, on the back and on the edges. Having stripped the extratec and edge tapes, I set out with a towel, linseed oil and steamer with me and did exactly 5 bursts of steam, each not more than 10 sec on each ding on each bat and this is what I have to report -
1. Smoothened out big dings - No, the size of it remained the same, but the edges seemed to have softened out.
2. Small dings of 1 to 3 mm have disappeared - But really, do you guys really worry about dents so small?
3. Dents (sorry Craters) on the bat face remained as they were.
4. The steam seemed to have cleared up the linseed oil coating. So, I have oiled the bats again.
Quite frankly, I have not seen any significant differences between the before and after scenarios here. The bats were oiled, dried and replacement extratec on them. Didn't feel a thing in the nets - the bats were exactly the same. If anything, a few minor, inconsequential dents have disappeared. That is all there is to it.
Is it worth the pain? No. Shall I do it again? Never.
Pages: 1 2 [3]
