Bandsaw for cricket bats
Author Topic: Bandsaw for cricket bats  (Read 1779 times)
nicko95
« on: March 11, 2015, 07:58:12 AM »
hey guys just wondering what size bandsaw id need to cut splices for cricket bat repairs i know a 16inch bandsaw can do the job but can a 14 inch bandsaw ?
http://www.carbatec.com.au/14-heavy-duty-bandsaw-ctj-3501_c19205
http://www.carbatec.com.au/jet-16-bandsaw_c22228
Re: Bandsaw for cricket bats
« Reply #1 on: March 11, 2015, 08:38:55 AM »
its more about the power of the machine, selecting the right blade and ensuring its set up properly.
you want a machine with a bit og power to it. I selected mine based on a few reviews and seeing what it could cut and what thickness. plenty of youtube videos and reviews around
nicko95
« Reply #2 on: March 11, 2015, 08:42:06 AM »
off the top of your head how much hp does your bandsaw have if you can remember
« Reply #3 on: March 11, 2015, 04:33:44 PM »
2 I think. I did have one that was around 1.5 and that was ok.
Ryan
  • Trade Count: (+17)
« Reply #4 on: March 11, 2015, 09:19:26 PM »
That'll do the job mate, imo it's all about the blade. Anything around 1HP would be fine, just make sure you have around 200/300 clearance so you have room for the cleft and jig.
nicko95
« Reply #5 on: March 12, 2015, 09:32:21 AM »
These are the specs of a 14inch  bandsaw im looking at, ill be usuing it to repair handles and the odd cleft will that be enough clearance
motor   1HP, 230V, 1PH, 10A plug
cutting depth   200mm
cutting width   345mm
maximum rip   300mm
table size   360 x 360mm
table tilt   -15° to +45°
table height   1070mm
positive stops   0 - adjustable
wheel type   cast alloy
wheel diameter   350mm
blade length   2553mm
blade guide type   ball bearing with rack and pinion crank
blade release type   quick release lever action
min saw blade width   1/4" (6.35mm)
max saw blade width   5/8" (16mm)
switch type   mechanical push button
dust port   1 x 100mm
stand included?   yes
workshop footprint   710 x 710 x 1760mm
net weight   77kg
shipping weight   85kg
packing size   1230 x 460 x 580mm
Ryan
« Reply #6 on: March 17, 2015, 10:07:14 PM »
That'll do the trick.
