Grip Grip
Pages: 1 [2] 3 4
Author Topic: Grip Grip  (Read 12270 times)
Re: Grip Grip
« Reply #15 on: April 09, 2015, 01:43:02 PM »
If you use 2 grips what's the benefit??
Makes everything even more pingy 😄
Re: Grip Grip
« Reply #16 on: April 09, 2015, 01:45:41 PM »
Might just use it all over the handle then lol
Re: Grip Grip
« Reply #17 on: April 09, 2015, 01:46:42 PM »
As it happens, I don't think it'd make any difference if you use two grips. Only if you use one
Re: Grip Grip
« Reply #18 on: April 09, 2015, 01:47:27 PM »
My thoughts exactly...
HallamKeeper
Re: Grip Grip
« Reply #19 on: April 09, 2015, 02:08:35 PM »
I've always used two grips and the bottom one gradually moves, so I use it to secure the bottom one and then use a bit more between grips just in case.
Re: Grip Grip
« Reply #20 on: April 09, 2015, 02:09:36 PM »
And that works ok @CalverKeeper ?
HallamKeeper
Re: Grip Grip
« Reply #21 on: April 09, 2015, 02:18:03 PM »
Hasn't moved at all so can't complain. I spend at least an hour a week batting (I really should be better) so it gets pretty well tested.
northernboy1987
Re: Grip Grip
« Reply #22 on: April 09, 2015, 03:47:13 PM »
Yeah you should be able to pick up a 10mtr roll of self amalgamating tape for around a fiver for half decent stuff, grip grip is about £8 for a considerably smaller roll! As far as I can tell it is exactly the same stuff, certainly works using the same principle anyways (rubber on rubber)
Re: Grip Grip
« Reply #23 on: April 09, 2015, 03:57:19 PM »
Good call on the amalgamating tape. I popped out and got some from Toolstation for £3.45, applied to the handles of the size 1 and size 4 and now the grips fit snugly.
Now the bottom handed biffers at the club shall suffer grip creep no more.
liscon12
Re: Grip Grip
« Reply #24 on: April 09, 2015, 04:25:25 PM »
£3.99 for a 10m roll from ScrewFix, worth a punt I think
northernboy1987
Re: Grip Grip
« Reply #25 on: April 09, 2015, 08:06:38 PM »
£3.99? Bloody ScrewFix, looks like I'll have to shave a pound or so off my price haha! Hard work being an independent wholesaler!!
Shortpitch
Re: Grip Grip
« Reply #26 on: April 09, 2015, 08:33:40 PM »
I finally got my grip grip delivered, Just as you guys mentioned in the above posts its nothing but a self-amalgamating tape ???. I did put the Grip grip on the bats and have used it in Nets. Its worked fine, but its way cheaper to get the self-amalgamating tape than the Grip Grip for sure.
liscon12
Re: Grip Grip
« Reply #27 on: April 12, 2015, 01:31:42 PM »
Got that Screwfix Amalgamating tape and it looks like GripGrip but since I've not bought any myself I can't compare. Have put it on both mine and my brothers bats so we'll see how it goes, a bargain if it works!
Re: Grip Grip
« Reply #28 on: April 12, 2015, 07:19:09 PM »
I got the amalgamating tape off eBay. £1 for a metre roll delivered
I used to glue/tape adjust grips constantly , but the tapes held no bother
Re: Grip Grip
« Reply #29 on: April 12, 2015, 09:53:00 PM »
http://www.ebay.co.uk/itm/Self-Amalgamating-Rubber-Sealing-Tape-Satellite-1m-size-/350344422479?pt=LH_DefaultDomain_3&hash=item519227a44f
Makes you wonder if they are just re-packaging it and adding a huge markup.
Pages: 1 [2] 3 4
