Author Topic: how can i bat with a bruised thumb?  (Read 4581 times)
« on: April 04, 2015, 04:21:22 PM »
my bottom hand, has a bruised thumb (fielding drill gone wrong). not much swelling, but hurts like hell when i hit the ball hard slightly off center. have a game coming up - is there a way i can minimize the constant agony?
wrap it up tightly, and then put the glove on to provide more cushion?
Re: how can i bat with a bruised thumb?
« Reply #1 on: April 04, 2015, 04:23:57 PM »
Pop a painkiller before you bat and grit your teeth?  ;)
treefeller
« Reply #2 on: April 04, 2015, 04:31:39 PM »
I had the same problem last year and used some Ibuprofen gel which worked surprisingly well
« Reply #3 on: April 04, 2015, 04:48:50 PM »
I tore a ligament in my thumb.
Missed a few nets. Then just braced it. Hurt like hell. So I manned up abit and just got on with it.
StandUpKeeps
  • 'Confidence Is The Key In Cricket'
« Reply #4 on: April 04, 2015, 05:05:42 PM »
Maybe try co-ban for night treatment it have you considered finger guards?? As a keeper it's a common problem so that's what I use.
« Reply #5 on: April 04, 2015, 06:13:13 PM »
Wouldn't it be better just to wait till it's better to save long term damage???
« Reply #6 on: April 04, 2015, 07:15:12 PM »
Simple, middle every delivery and stroke the ball into gaps.
Giraffe208
« Reply #7 on: April 04, 2015, 07:25:23 PM »
Doing this will also enable the purchase of at least 1 more bat to determine if it fits more comfortably against your thumb on impact
« Reply #8 on: April 05, 2015, 01:00:20 AM »
not to worry...the possibility of such an injury was what I used to justify all prior purchases.
Jenko
« Reply #9 on: April 05, 2015, 01:08:16 AM »
If you were playing in Australia some might recommend a teaspoon of cement :)
Honestly never had a bruised thumb. Do suffer from lower back and hamstring stiffness/soreness though and I usually munch on ibuprofen (Nurofen) to get through games
awp
« Reply #10 on: April 05, 2015, 06:21:32 AM »
Geez you poms are soft, magic spray and get on with it
Hoover
« Reply #11 on: April 05, 2015, 06:22:18 AM »
Get the lightest bat you can, even a harrow.
Practise gripping super tight with your top hand. Providing you don't pull you should get through an innings. The light bat should make it manageable. Good luck.
« Reply #12 on: April 05, 2015, 06:25:23 AM »
sounds like you have a broken thumb...
HallamKeeper
« Reply #13 on: April 07, 2015, 08:24:10 PM »
I had a really bad thumb at the end of 2013 season, serves me right for being a keeper. Couldn't grip the bat well with my bottom hand at all but I just tried to hang around. It actually helped me play straight and the adrenaline got me to my first hundred. I think I taped it a little on the joints to restrict movement caused by vibration more than anything but not so much to stop me being able to bend it.
Generally for bruised digits I ice a lot. Use arnica as many times a day as I can and if I must, use ibuprofen. I try not to use pain killers and ibuprofen tablets unless I really need to. Not convinced it is good for your stomach.
