Author Topic: Running repairs  (Read 5409 times)
Boondougal
Running repairs
« on: April 06, 2015, 10:47:17 AM »
So i have been using my custom Red Ink x3 in the nets this winter and very pleased with it. I liked the look of John bats but i also wanted to experiment with a bat that had closer to SSH dimensions so i thought i would take the plunge and het one made.
I certainly spent some time knocking it in, from what i read on here it was definitely more than some but less than others. The edges were rounded nicely and the face was at the point where the mallet no longer made an indent.
I have loved the bat in nets and it definitely suits me, but despite my impeccable timing  :o :o the bat needs a few running repairs.
I laid a load of glue in it yesterday (infilling a few times) and will be sanding it back later today.
Re: Running repairs
« Reply #1 on: April 06, 2015, 11:01:31 AM »
Seam marks. Needs more knocking in bud  ;)
simonmay5
Re: Running repairs
« Reply #2 on: April 06, 2015, 11:03:49 AM »
I think it needs more knocking in as seam marks are showing or the balls you are using are rock hard
Boondougal
Re: Running repairs
« Reply #3 on: April 06, 2015, 11:32:02 AM »
Yeah, your both right but i literally couldn't make a mark on the face no matter how hard i hit it with the mallet. The balls in nets were good, 100% certain on that.
If anything i should have gone a little more steady in the nets but when the balls in the cow arc, cow corner the ball needs to go! (favourite and only shot!)
I'm not worried about it too be honest, i got it as a bit of an experiment and its worked out well. I obviously want it too last as long as possible but its looking unlikely i will play much this season now so my idea to get another one made to similar specs but in a better grade has been put on the back burner until it looks like i will play more.
Re: Running repairs
« Reply #4 on: April 06, 2015, 11:42:38 AM »
@Come in 5 and left a bit can sort out a good repair
Re: Running repairs
« Reply #5 on: April 06, 2015, 12:16:07 PM »
Personal opinion is bat breaking balls.
You say they were good balls? Any particular brand or just a random lot of ex game balls?
Re: Running repairs
« Reply #6 on: April 06, 2015, 12:22:22 PM »
Yeah, I would agree with the balls comment, or the willows very dry?
Would try and get a scuff sheet on it, if it can be repaired just to give a little bit more protection
Giraffe208
Re: Running repairs
« Reply #7 on: April 06, 2015, 12:38:54 PM »
This would be my opinion aswell. Seam marks are one thing but to cause that sort of damage that quickly is a good effort! Either the balls or you were going hammer and tongs!
Boondougal
Re: Running repairs
« Reply #8 on: April 06, 2015, 12:42:09 PM »
Well I wasn't holding back. Balls will have been fine. I was netting with the Vitas crew and bag o balls were fine from what I could see.
I agree with most that more knocking in would prob be needed but it's all glued up now ready to sand later. I'll get the mallet out after finishing to see if I can get it a little harder.
Re: Running repairs
« Reply #9 on: April 06, 2015, 01:16:42 PM »
Mostly top of the line used Tiflex league balls at my clubs nets. Not sure if Sam has been netting elsewhere too, but i can 100% say the balls we use aren't poo.
mp07
Re: Running repairs
« Reply #10 on: April 06, 2015, 02:16:52 PM »
it looks pretty dry...did you oil it?
Boondougal
Running repairs
« Reply #11 on: April 06, 2015, 02:29:45 PM »
As @fattus cattus would say... No issues with the quality of jakes ball bag.
As with most of my game the issue is the thing between the bat and the floor.
Boondougal
Re: Running repairs
« Reply #12 on: April 06, 2015, 02:30:44 PM »
Yep. Defo did
Re: Running repairs
« Reply #13 on: April 06, 2015, 02:34:18 PM »
I only ask.  As I recieved similar damage (dent and cracks, not seam marks) from a sports direct ball on one of my bats I'd scored 500 plus runs with (so was knocked in)
But if jake says there good balls. There good balls. Very bizarre damage.
Time to give it more beef with the mallet.
Boondougal
Re: Running repairs
« Reply #14 on: April 06, 2015, 02:39:48 PM »
Well 30 mins later here is the result. Glued it yesterday.
Orbital sander, 180 grit. 800 grit to finish. Oil
It might be a little dry... Who knows!
Like I said I'm not fussed about the damage, it was incredible value from red ink and made me realise what a proper bat could do to help my game.
Plus when this goes I have a Ssh H4l to bring into service!!!
