Pages: [1] 2 3 4
Author Topic: Correct Mositure Level For Bats  (Read 13987 times)
« on: April 06, 2015, 04:21:55 PM »
What is the correct moisture level for cricket bats? I want to measures the moisture using an industrial/generic Mositure meter.
Re: Correct Mositure Level For Bats
« Reply #1 on: April 06, 2015, 04:27:25 PM »
10 percent.
RF
« Reply #2 on: April 06, 2015, 04:31:45 PM »
You'll put holes in your bat though??
« Reply #3 on: April 06, 2015, 04:35:11 PM »
You rest it against the surface of the wood...no holes needed.
« Reply #4 on: April 06, 2015, 04:35:39 PM »
10 percent.
Amplus came out at 8 percent. Cause for concern?
Chalkie
« Reply #5 on: April 06, 2015, 04:44:48 PM »
Would be interested to know the levels in recent purchases from OLS as some people say that they must be drier to have such big edges for the weights?
« Reply #6 on: April 06, 2015, 04:46:14 PM »
No set levels it between 8-12 per cent depends on where bat is made how williow is stored
Some Asian brands take it down to 4-6 per cent
RF
« Reply #7 on: April 06, 2015, 04:56:41 PM »
You wouldn't get such a good reading without actually penetrating the timber, the current needs to run through the timber for an accurate measurement.
Bats at 4-6% would pick up more moisture and weight when they got to England anyway, you can't keep them that dry in this climate
« Reply #8 on: April 06, 2015, 04:57:14 PM »
Or not full width
Or not full size
Or all 3. Take your pick.
« Reply #9 on: April 06, 2015, 05:25:20 PM »
We shall talk later ref this net buddy
CrickFreak
« Reply #10 on: April 06, 2015, 06:19:54 PM »
I dont think the retailers dry the bat or reduce the blade size lol
Its the batmaker and will be same whether bought from overseas or local retailer.
Anyways, back to the topic. Is there a scientific study on how moisture effects bat size? Not sure how much overdrying a cleft results in bigger bat size. Interested in seeing - x% lesser content results in y% increase in overall volume of the cleft.
« Last Edit: April 06, 2015, 06:25:37 PM by CrickFreak »
abdulwq
« Reply #11 on: April 09, 2015, 12:30:18 AM »
Is it possible to moisturize the bat with little water spray and then oil it to increase moisture content or a bad idea.
alee
« Reply #12 on: April 09, 2015, 01:37:28 AM »
Some people say that if you oil a dry bat then it would be fine?
abdulwq
« Reply #13 on: April 09, 2015, 07:50:27 AM »
But the oil does not penetrate lot...it stays on surface and works a s sealant...
« Reply #14 on: April 09, 2015, 07:57:12 AM »
No
The oil stops the moisture getting out. A bit late if the bat has dried.
Pages: [1] 2 3 4
