Author Topic: Edge/toe damage - advice please  (Read 2188 times)
« on: May 10, 2015, 06:48:26 PM »
Evening all
As I'm not able to play for a while I thought I'd try to give my bat a bit of a spring clean.
I noticed there were a couple of cracks down the inside edge.
Hopefully you can see what's going on from the pictures. My question is, do I leave it and hope for the best, or take the scuff sheet off and get some glue in there?
simonmay5
Re: Edge/toe damage - advice please
« Reply #1 on: May 10, 2015, 07:19:21 PM »
I think I would take the scuff sheet off and put some glue in it so it does not get any worse
Bruce
« Reply #2 on: May 10, 2015, 08:25:23 PM »
Cam, where are you based again?
My bat needs a refurb can I drop it into you? Can you message me cost?
« Reply #3 on: May 10, 2015, 09:19:10 PM »
Scuff sheet is off and there were two separate cracks.
I've cleaned the residue from the scuff sheet off and given it a sand.
Now it's over to eBay and Royal Mail to deliver some syringes and needles before I can progress with the repair.
It might be a blessing in disguise I can't play next weekend as I have no reason to dish the repair now.
iand123
« Reply #4 on: May 11, 2015, 07:18:47 AM »
what syringes/needles did you order? I got some but they were rubbish but equally i think i was just being a bit thick. What mix glue to water (if you mix it down at all) do you use?
« Reply #5 on: May 11, 2015, 07:41:19 AM »
Give me your address I will post you some. Don't mix water with the glue. The needles I use are about 50mm long and have a green end. The shorter, heroin addict ones are too narrow. Just make sure you don't leave the glue in either the needle or syringe.
« Reply #6 on: May 13, 2015, 09:19:10 PM »
Toe guard off, needle in, leave a few hours.
Sealed, solid, a light sand and scuffed
sarg
    • CricketBatInfo
« Reply #7 on: May 19, 2015, 04:29:35 AM »
Also lookup dispensing needles on ebay.
« Reply #8 on: May 19, 2015, 05:09:53 AM »
I use these
« Last Edit: May 19, 2015, 05:11:44 AM by Gurujames »
