Author Topic: When to put on scuff sheet?  (Read 2815 times)
addidasf55
« on: June 05, 2015, 05:23:22 PM »
So I'm an amateur when it comes to bat care and prep. I usually just get someone else to do it. I got a new bat a couple of weeks ago, gave it in to be oiled and knocked in. Also gave in a Newbury scuff sheet to be applied but the guy said he didn't want to put on the scuff sheet straight after knocking it in and oiling it?
I never asked any further but when do you put the sheet on then because I don't want to use the bat in training without a scuff sheet.
Re: When to put on scuff sheet?
« Reply #1 on: June 05, 2015, 05:27:43 PM »
Once the oiled has thoroughly dried prior to use.
addidasf55
« Reply #2 on: June 05, 2015, 05:35:17 PM »
Any way of figuring out when that would be?/ should I put it in a drying cupboard?
Cin88
« Reply #3 on: June 05, 2015, 05:39:45 PM »
Heavens no! That will just ruin your bat. Just leave it about 24-48 hours after you've oiled it, it'll be dry enough then.
addidasf55
« Reply #4 on: June 05, 2015, 05:59:31 PM »
Okay thought so, only mentioned airing cupboard because folk have mentioned it in the past. Never done it myself.
Bambooman
« Reply #5 on: June 05, 2015, 06:46:58 PM »
Depends how much oil you've applied. I would leave it as long as you possibly can may even be a week.
I would also test it with some masking tape before you decide to apply the scuff. If the masking tape sticks ok then you should be alright.
« Reply #6 on: June 05, 2015, 07:35:23 PM »
Apologies if you already know bats are placed  in airing cupboards in an attempt to reduce the bats weight.
« Last Edit: June 05, 2015, 07:43:25 PM by Seniorplayer »
addidasf55
« Reply #7 on: June 05, 2015, 10:59:54 PM »
Cheers man. Guess I'll wait, the bat was still quite soft today so guess there's still oil there to be dried. Good idea about the masking tape :)
Slogger
« Reply #8 on: June 05, 2015, 11:16:23 PM »
I usually find its a good idea to give the entire face a once over with a mallet after the oil has dried. I find it gets rid of the sheen that the linseed can leave.
