Bat grades
Author Topic: Bat grades  (Read 4424 times)
Jacobmcc123
Bat grades
« on: August 23, 2015, 04:16:43 PM »
What is the difference between a Grade one bat and a grade one +, for example Salix have 3 types of grade one. Normal grade one, players and finite. Is it really worth paying £100 more for a bat because it's more limited? The performance can't be much different can it?
Re: Bat grades
« Reply #1 on: August 23, 2015, 05:55:51 PM »
The difference is the quality of the willow the higher the grade the more premium the willow : white willow with straight grains optimum cosmetic appearance  clean hitting area with an outstanding weight to profile ratio
Re: Bat grades
« Reply #2 on: August 23, 2015, 06:07:45 PM »
Can open, worms, everywhere...
Jacobmcc123
Re: Bat grades
« Reply #3 on: August 23, 2015, 06:23:55 PM »
Wasn't trying to cause problems just a valid question
Jacobmcc123
Re: Bat grades
« Reply #4 on: August 23, 2015, 06:24:20 PM »
Thanks
Re: Bat grades
« Reply #5 on: August 23, 2015, 07:01:56 PM »
potzy248
Re: Bat grades
« Reply #6 on: August 23, 2015, 08:56:41 PM »
Mate, if you have a look around the forum there are heaps of topics talking about this issue. Basically though, top grades look better, perform quicker and are lighter.
Topgun
Re: Bat grades
« Reply #7 on: August 24, 2015, 01:29:36 AM »
Bats are graded by its looks not performance. So a lower grade willow could easily perform better than a g1+. Since the willow is cosmetically not favorable, people buy g2+. But people who dont really care about the look they will usually buy a cheaper bat.
Topgun
Re: Bat grades
« Reply #8 on: August 24, 2015, 01:31:47 AM »
Its Just cricket made a video on this topic, its really informative so check that out
Re: Bat grades
« Reply #9 on: August 24, 2015, 11:21:41 AM »
It could but I have not come across low grade willow that does.
Re: Bat grades
« Reply #10 on: August 24, 2015, 11:22:51 AM »
But many many others have.
Re: Bat grades
« Reply #11 on: August 24, 2015, 11:31:17 AM »
Well Chris I  once had an ex county  low denesty pros bat given to me the pickup for the wieght was so light it also pinged better than any other bat I had before or since even the handmade ones I paid top money for the willow just felt different in the hands this also confirmed to me proper pro clefts are not generally available to the paying bat buyers.
« Last Edit: August 24, 2015, 12:39:54 PM by Seniorplayer »
Jacobmcc123
Re: Bat grades
« Reply #12 on: August 24, 2015, 01:31:36 PM »
From what I've found no matter what bat you have if you middle it, it will go to the boundary.
Topgun
Re: Bat grades
« Reply #13 on: August 24, 2015, 02:11:14 PM »
They are all the same - g1,g2,g3. they are all the same english willow coming for same trees. The only difference is that some clefts have more grains, less blemishes etc. Pretty simple
Re: Bat grades
« Reply #14 on: August 24, 2015, 04:09:45 PM »
If that's the case I better put my  bat made from a Low density crown cleft up for sale....
« Last Edit: August 24, 2015, 04:49:52 PM by Seniorplayer »
