The new TCK "Pepsi"50mm edge big bat 2016
Pages: 1 2 [3] 4 5 ... 8
Author Topic: The new TCK "Pepsi"50mm edge big bat 2016  (Read 46960 times)
liscon12
Re: The new TCK "Pepsi"50mm edge big bat 2016
« Reply #30 on: September 27, 2015, 06:20:44 PM »
That's good to hear, I just assumed with it being more wood meaning more money. Apologies
sarg
    • CricketBatInfo
« Reply #31 on: September 27, 2015, 09:15:15 PM »
What are the shaped going from left to right?
Left Db2 2.9 , Middle Bespoke 2.95, Right Long Handled shortened Tonto Butterfly 2.105. GM grips are about 2.2 ounces on each bat with, some grip off cut under the handle to make the pickup even lighter.
Middle was designed by Adelaide, AUS rep Andrew Duffield. Streaky apparently reckons its a new Db1, but its only got a 1mm scope and a bit more wood higher above the meat.
moonball
  • Pitch it up, get your reward.
« Reply #32 on: September 28, 2015, 07:18:33 AM »
Be interesting to know how long your gloves last, got a pair for my lad, used at indoor nets only, worn through on two of the fingers before even playing a game... so, we have virtually brand new gloves, useless to him. Had to get other gloves - another brand - when B3 didn't replace. Best of luck.
« Reply #33 on: September 28, 2015, 08:03:27 AM »
Sorry to hear this it doesnt sound like our customer service we replace faulty softs..
Please pm me and i will see what i can do.
We have had not many issue with the older style softs which are pictured and our new softs
moonball
« Reply #34 on: September 28, 2015, 10:48:25 AM »
PM sent.
The Doctor
« Reply #35 on: September 28, 2015, 03:14:09 PM »
Hopefully I will cover all questions, but if I have missed anything please let me know and I will answer.
"Project Pepsi"
The idea was simple; to get a big bat light, after my magicians hat would only magic white rabbits and not willow I had to put my thinking cap back on and create a design that was big (and had an associated heavy dead weight) but actually felt light in the hands.
By playing around with the Centre of Gravity (COG) we have got to an "optimum" size vs pick up ratio, (the higher the COG the lower the Moment of inertia - the easier it is to rotate (swing)). As this bat is so big, the middle has to be high, but when you compare it to a “normal – mid swelled bat” there is still more volume lower down in the “pepsi”
Vital Statistics;
Weight start from 2lb 12.5oz – average weight would be 2lb 14oz, and can go up to 3lb 6oz Bear in mind that due to the design these “pick up” approx 2oz lighter (I would say a little more like 3oz)
Price – same as our normal bats (SERIES)
We have 6 currently being made in the factory for the showroom, we had one in the showroom but the first person that came in and saw it brought it.
If you have any further questions, please don’t hesitate to ask.
Streaky
dbacon1980@gmail.com
Never stand still
Bowlers Name Please
« Reply #36 on: September 28, 2015, 03:25:00 PM »
Hopefully they'll be some in the showroom when I come down to drop this years bat off for its refurb @The Doctor  . Might be too heavy for me but you never know!  :)
« Reply #37 on: September 28, 2015, 04:24:48 PM »
Streaky, if any come out in the 3.2 or bigger weight, let me know. Wady is after a new one!
liscon12
« Reply #38 on: September 28, 2015, 04:30:01 PM »
So you can get one of these bad boys for 150?
« Reply #39 on: September 28, 2015, 05:49:40 PM »
"Project Pepsi"
Vital Statistics;
Streaky
All sounds good to me.
Just wondered what you meant by Average Weight - 400 density? and is the start weight determined by keeping to 50mm edge? Could you for example have a 45mm version at a lighter weight or a harrow length version at 2'11?
« Reply #40 on: September 28, 2015, 06:04:23 PM »
Series 1 stripe is currently that price pal  :D
trypewriter
« Reply #41 on: September 28, 2015, 07:28:08 PM »
Theoretically too heavy for me - I'd like to see one though!  ;)
sarg
    • CricketBatInfo
« Reply #42 on: September 29, 2015, 02:56:02 AM »
"Project Pepsi"
Vital Statistics;
Streaky
Hi Streaky,
What's your thoughts on bowing the blade. Does this improve pickup? If it does how come didn't use this?
Marc
« Last Edit: September 29, 2015, 07:20:56 AM by sarg »
The Doctor
« Reply #43 on: September 29, 2015, 10:47:08 AM »
Hi Nick,
Yup - average weight 400 density.
We can change the model anyway you like, but that then wont be a SERIES shape and cost you a little bit more (£50) for a BESPOKE design. You can however go to Harrow width / super short blade/LH and that will loose you approx 2 to 3 oz.
Never stand still
The Doctor
« Reply #44 on: September 29, 2015, 10:47:45 AM »
Chris,
Wont be a problem getting one that weight - bat makers dream.
Never stand still
