Author Topic: Old balls and laquer, varnish or other shiny stuff  (Read 3192 times)
SteffanLangholz
    • Teams webpage
« on: October 01, 2015, 09:20:27 PM »
Hi guys..
I played a season down under, and witnessed something odd at the club, odd to me at least.
The coach would take the bucket of old balls, and brush them with either laquer or varnish to make them withstand water, and regain shine. Sort of like the outer shell on a new ball. Can anyone deduct what this would be? And could it be harmful to the bats etc.?
Ams4287
Re: Old balls and laquer, varnish or other shiny stuff
« Reply #1 on: October 01, 2015, 09:41:30 PM »
I did get a refurb kit from dukes 4 or 5 years ago which I've used on balls - thinners to clean up the ball then piladene to re lacquer (not quite as good as new but does a job)
Cin88
« Reply #2 on: October 01, 2015, 10:13:22 PM »
Probably varnish and if so, i'd be slightly concerned myself. If it's just the same sort of laquer Dukes and other companies use then there's probably no cause for concern.
Personally, being an eczema sufferer, i've found that Oilatum (essentially white paraffin and various oily chemicals) is quite a good short term substance for getting the shine back on a ball, it doesn't last long though and I in no way condone it's use in a match situation. It's funny what you can discover completely by accident.
« Reply #3 on: October 02, 2015, 08:42:08 AM »
Cricket balls covered in lacquer allows the ball to last longer but it effects the balls bounce and the feel in the hands.
New balls coated with lacquer are cheap balls.
High quality balls such as Dukes are coated with thin layers of high quality polish.
« Last Edit: October 02, 2015, 10:04:32 AM by Seniorplayer »
« Reply #4 on: October 02, 2015, 08:59:54 AM »
One of the lads at last years dotball net had a re lacquered ball. Felt Wierd of the bat.
« Reply #5 on: October 02, 2015, 01:38:15 PM »
Sounds like a decent idea to reduce costs on training balls if it works, makes a big difference if you can train with balls that swing.
SteffanLangholz
    • Teams webpage
« Reply #6 on: October 03, 2015, 02:33:45 PM »
Im pretty sure this wasnt the case i Perth :p He had it in a 1 liter tin..
Yeah, they felt wrong. Especially since he tend to hit the seam. I wouldnt know about the bounce, since this was my first time ever on an actual grass pitch.
My thought too.
