Author Topic: Grip set-up: Heavy bat small hands  (Read 5958 times)
windyroad
« on: October 10, 2015, 07:50:41 PM »
Looking for some ideas for grip set up for those of you who use heavy bats but are afflicted with the curse of small hands. When I add a second grip to counter act the weight of the blade the handle started to feel uncomfortably thick and un-tactile.  Does anyone know of a fix?
alexhilly1492
Re: Grip set-up: Heavy bat small hands
« Reply #1 on: October 10, 2015, 07:55:27 PM »
try one and a half grips or a thicker grip? so spiral rather than chevron for example?
BB: 7-4-9-5, 7.3-0-29-5
« Reply #2 on: October 10, 2015, 07:57:16 PM »
How high up the handle do you hold the bat?
Lead tape around the very top of the handle and under the one grip may help as a counter balance(Google jaque Kallis bats for what I mean)
« Reply #3 on: October 10, 2015, 08:16:19 PM »
Some try golf lead tape around the top of the bat handle under the grip but you need a lot of tape and it's not cheap.
I cut a strip of lead about an inch wide taped it tight  all around  the top of the handle under the grip that worked but was a bit bulky
For me the  best solution although it reduces the weight of the handle  and therefore  initially effects the pickup is to reduce the handle diameter to around 1 inch thick and then build up the handle using thin chevron grips till I get the feel and pickup required usually just one grip suffices.
« Last Edit: October 10, 2015, 08:23:50 PM by Seniorplayer »
« Reply #4 on: October 10, 2015, 08:17:33 PM »
I use youth size gloves and bat with a 2.10 and a 2.12. In my view the weight is no issue. If the bat feels heavy it is probably not the bat for you.
« Last Edit: October 11, 2015, 10:32:07 AM by Gurujames »
« Reply #5 on: October 10, 2015, 08:21:57 PM »
I use youth size. In my view the weight is no issue, just the fact that you can wrap it around. The missus agrees!!!!
Youth size bat?
windyroad
« Reply #6 on: October 10, 2015, 08:35:54 PM »
Fairly standard mid grip.  The Kallis tape method looks worth a try.  I am loath to add much more weight to the bat is my only reservation-it's 3lb 3oz with one grip-any heavier and by 35 I am beginning to tire.  Hopefully by counterwieghting it will actually seem lighter in the hand.
« Reply #7 on: October 10, 2015, 08:45:13 PM »
Here is my setup:
- thin handle
- thin full length grip on the entire handle
- second grip on the upper half of the bat and remaining grip rolled-up around the top 1-inch of the handle. This rolled-up grip acts as a counter weight since I use heavy bats.
Works like a charm and balances out the bat; people who pick up my bats say that they don't feel heavy.
« Reply #8 on: October 10, 2015, 08:48:10 PM »
Easy solution to that, make sure you don't get to 35! Just leave a straight one in the 20's every week, problem solved  ;)
Cin88
« Reply #9 on: October 10, 2015, 08:50:11 PM »
I personally use two thick grips if I have a heavy feeling bat, especially with my GN Powerbow. I have tiny hands but I don't find the extra grip an issue, it helps lessen the vibration problem for me as well as my Powerbow is mostly definitely on the downward slope towards being a dead plank.
« Reply #10 on: October 10, 2015, 08:53:09 PM »
So just to confirm you bought a bat that is too heavy for you and you want to solve the issue by adding weight?
How about you shave an oz or so from around the toe or add a little concaving to take a little weight from the bat.
trypewriter
« Reply #11 on: October 10, 2015, 09:01:52 PM »
Agree with Buzz, counterbalancing won't do it. IMO you need to reduce the dead weight.
windyroad
« Reply #12 on: October 10, 2015, 09:04:54 PM »
It's not a weight issue.  I have used heavier without any problems.  It is more of a balance issue.  I wanted the sweetspot lower in my new bat but that comes with the obvious balance trade off.  While others can add an extra grip and solve the problem I cannot without it feeling too thick owing to my silly child hands.
« Reply #13 on: October 10, 2015, 09:31:06 PM »
I do this more for the feel in my hands than because I want to counter balance a bat, but the added weight up top may help you out. Here's what I do to all my bats.
An extra half layer of binding using extra thick twine (jewellery cotton cord in this case) to the bottom half of the handle. The twine/cord is bought as 2mm on eBay and comes in 10m lengths. I use almost all of a length to do each bat.
Once the additional binding is added and the glue has set it adds roughly 1oz of weight.
The above 2 pictures are on a thicker handle, so I have applied a single chevron over the top. If the handle is thinner I will apply a thicker grip, my preference being a spiral or a ripple.
Here are two bats next to each other, the one with the ripple applied had a thinner handle to begin with, but I doubt you'd be able to tell them apart in a blind test now.
« Reply #14 on: October 10, 2015, 09:32:03 PM »
The other problems with the bat handle being to thick is controlling your shots and keeping grip on the handle in particular the bottom hand during the follow through.
