Adding weight to a middling bat - My guide
Author Topic: Adding weight to a middling bat - My guide  (Read 3054 times)
SteffanLangholz
    • Teams webpage
« on: November 09, 2015, 06:59:15 PM »
Few weeks ago, I asked how to apply weight to a middling bat, affordably and at home. I've tried two different ways, which both included a broken bat. Both needed to hit a specific weight, the one this guide is on, had to be 2.9 as per my buddies requirements.
One way:
1. First, cut the bat - I cut 20mm of each edge, followed by 10mm on each side again (to hide the operation)
2. Then weigh it, find out how much steel you need.
3. I use 10mm roundsteel, which is around 7 grams pr cm. Cut them in pieces that will fit in the bat, being 4 cm in my case. Remember the 10mm edges also weigh in later again.
4. Apply the steel with masking tape through the length of the bat, try to feel out the balance of the bat. The further towards the handle, the lighter the pickup.
5. Cut the holes for the roundsteel - I used a 10mm drill, masked for the width allowed without going all the way through
6. Lube the roundsteel in glue, I used PWA, and pin them through the holes.
7. Reapply the edges, hiding the steel.
8. Wait under pressure
9. Done and dusted, weighing in at 2.9 Lucky! - I had not taken into account that my tablesaw would steel .5-1 mm of wood, so theres an edge between the chips unfortunately.
Second way (No pictures):
7. Lube the wooden pegs, cover the hole, and sand them down to fall in one with the bat edges.
bostoncricketer
Re: Adding weight to a middling bat - My guide
« Reply #1 on: November 09, 2015, 09:15:41 PM »
Pretty awesome. How much time did it take you from start to finish? Did you use any power tools to cut the bat and the roundsteel?
SteffanLangholz
    • Teams webpage
« Reply #2 on: November 09, 2015, 09:31:35 PM »
I used a tablesaw for cutting the blade for the bat on the pictures. I did another with a jigsaw, took a steady hand, but turned pretty good. Would say go for the second guide if you are going to use a jigsaw. Used a powerdrill for the holes. Would be able to sand it down by hand, but I'm too lazy and used a sander. Used a old school hacksaw for the roundsteel.
It took me around a ram slam t-20 innings and a bit.. So I guess 2-3 hours.
Sendt fra min D5803 med Tapatalk
gazr5
« Reply #3 on: November 10, 2015, 08:01:56 PM »
I need a shed and power tools to do man stuff like this
Sent from my HTC One mini 2 using Tapatalk
« Reply #4 on: November 10, 2015, 09:41:08 PM »
Alternatively buy one at the right weight :)
SteffanLangholz
    • Teams webpage
« Reply #5 on: November 11, 2015, 10:15:13 AM »
Well.. That's boring, and expensive. Having the tools, this set me back £6.
inzaghi316
« Reply #6 on: December 10, 2015, 12:44:39 PM »
Excellent
Sent from my ASUS_T00G using Tapatalk
114*(53), 100(35), 98*(37), 96(33), 83(44), 79(26),79(34), 68(30), 62(29),59*(30) TOP TEN innings.
