Pages: 1 ... 74 75 [76] 77 78 ... 121
Author Topic: South Africa vs England  (Read 281065 times)
Re: South Africa vs England
« Reply #1125 on: January 14, 2016, 11:37:39 AM »
Elgar's technique vs short bowling is interesting. He's leaning backwards every time he tries to pull/hook, that's only going one way.. in the air. I expect better from a top order player tbh, should at least be competent at 130kph to keep it down. (I'm assuming he can't based on playing it 4 times now and every time there are men out)
oh review on Amla
« Reply #1126 on: January 14, 2016, 11:39:06 AM »
So the middle stump will have cartwheeled off towards the stumper and it's not out??
Shocking decision.
« Reply #1127 on: January 14, 2016, 11:42:21 AM »
Shocking decision.
just clipping wasn't it??  doubt so not out. Did look high, above the knee roll etc. I'd have expected an umpire to give it not out as there was doubt there.
northernboy1987
« Reply #1128 on: January 14, 2016, 11:48:40 AM »
Stokes is raging, pushing 90mph now.
« Reply #1129 on: January 14, 2016, 11:52:13 AM »
starting to leak runs because of that though, needs taking out the attack as he's becoming erratic
« Reply #1130 on: January 14, 2016, 11:54:23 AM »
Do you have sky?
northernboy1987
« Reply #1131 on: January 14, 2016, 11:54:56 AM »
I'm at work so unfortunately having to rely on text updates telling me that his pace is increasing, could do with breaking this partnership soon!
« Reply #1132 on: January 14, 2016, 11:55:53 AM »
Do you have sky?
yeah, watching in on the ipad via skygo live
Stokes operating around 135kph so not quite 90mph!  He his going red like a beatroot though.. angry boy
From what I've seen of Elgar.. Pepper him with short balls and then throw them up swinging away outside his off stump as his feet won't move and he looks worse than Jos/Hales. His pull/hooks will go in the air (as they have today) so swap it around and bowl full outside off and surprise ball being short etc etc. Bowling poorly at Elgar given his obvious weakness
« Last Edit: January 14, 2016, 11:59:37 AM by ProCricketer1982 »
northernboy1987
« Reply #1133 on: January 14, 2016, 12:01:39 PM »
Like I said I was having to trust the BBC text coverage "He's pushing 90mph now, the Durham man. Wound up and bowling gas."
« Reply #1134 on: January 14, 2016, 12:02:27 PM »
ok Broad, I said he can't pull but bowling a half tracker at 130kph is a bit too easy even for Elgar.. crunching pull for 4. dispatched.. go pick that up Broady lad
yeah he's not pushing 90 unfortunately.. some Eng fan getting over excited again as Stokes is the hero currently
that's better, 135kph at Elgar and he fluffs it again..so poor for a opener
« Reply #1135 on: January 14, 2016, 12:09:07 PM »
since lunch at Elgar
40% short
40% length
20% full
Not good enough on this wicket, there is nibble in the wicket if you bowl full.
at amla
short - 42%
 length - 47%
full - 11%
« Reply #1136 on: January 14, 2016, 12:19:40 PM »
Turn for moeen.
« Reply #1137 on: January 14, 2016, 12:20:14 PM »
oh good god.. Elgar is awful
Moeen takes his wicket with a bog standard ball that barely did anything.. Bonus wicket again for England, now the key partnership for SA.. Get one of these in the next 5 overs and England should roll SA.
« Reply #1138 on: January 14, 2016, 12:22:04 PM »
AB assaulting Mo already. quick feet and four down the ground.
make that back to back 4's. AB counter attacking mr avg (only just cleared cook at midwicket though! so risky)
« Reply #1139 on: January 14, 2016, 12:33:16 PM »
Mo has gone ultra defensive. bowling around the wicket, aiming at middle-leg with 5 leg side fielders. Interesting passage of play, asking questions of AB's patience
Amla gone to a good ball from Finn.. full length, moved away and took the edge. Amla opened up a bit too much. Exactly where Eng should be bowling. good ball
SA could fall away now
