Author Topic: looking for a bat with the following specifications  (Read 1229 times)
chandrasekhar
« on: November 18, 2015, 04:24:53 PM »
Hello All
Iam looking for a bat in the weight range from 2-11lb to 2.15lb, pick up should be very very good. feel light once is done
grade 3 or 2  bat from  oversized cleft with  lot heart wood on rt handers outside edge, full heartwood its great.
min 9 grains fairly straight
butterfly marks are ok as long as they are on back side not on batting face
NO KNOTS on the wood plz
full profile very little concave if weight is too much
spine height 68-70 mm
edge 43-45 mm, rounded edges no sharp edges
thin ovel handle
mid to low middle
very small duckbill just 1 inch from toe
thick square toe(min 27mm toe thickness), thick shoulders(min 21mm)
very little to no bow
" PING SHOULD BE CRAZY LIKE PROS BAT NOT LIKE A DEAD WOOD"
what would be the price of the bat and postage cost to ohi usa
please contact me
waiting for your reply
thanks
Chandu
Re: looking for a bat with the following specifications
« Reply #1 on: November 18, 2015, 04:30:36 PM »
Hi Chandu, have a look at this:
http://custombats.co.uk/cbforum/index.php?topic=36439.0
Seeing as you're looking for a minimum of 9 grains, then you'd most likely have to go for a G2, not to say you can't get grainy G3s, it's just that they're slightly less common, especially in OS clefts! One thing I'd say is that you'd probably be able to customise that Pepsi shape if you contact B3, they'll probably chat to you via Skype or phone to make sure they get it spot on! (You'll probably have to customise, as the Pepsi has around 15mm shoulders) The pick up of the Pepsi is great, and should be even better if you make some tweaks to it. :)
Hope this helps!
ItsJustCricket
    • Its Just Cricket
Re: looking for a cricket bat
« Reply #2 on: November 18, 2015, 04:46:38 PM »
That doesn't sound like a Grade 2 or 3 - those specs are very hard to find, looking at an expensive bat!
The Doctor
« Reply #3 on: November 18, 2015, 04:47:43 PM »
I think with those specs you are looking at a grade 2 - I have sent you a picture of three clefts for you to look through.
Streaky
dbacon1980@gmail.com
Never stand still
« Reply #4 on: November 18, 2015, 04:56:28 PM »
@chandrasekhar - I have merged your 2 bat topics together.
The Doctor
« Reply #5 on: November 18, 2015, 05:13:58 PM »
Streaky
I have this one also -
You wont get a blemish free face however as somebody has stated that would be a grade 1.
What do you think?
Streaky
Never stand still
