Author Topic: Is Magnetic Tape the same as Lead Tape  (Read 3677 times)
« on: December 11, 2015, 01:25:31 PM »
Not an expert so please educate me!
« Last Edit: December 11, 2015, 02:47:53 PM by uknsaunders »
Mel Jessop
Re: Is Metallic Tape the same as Lead Tape
« Reply #1 on: December 11, 2015, 01:42:54 PM »
Don't think so, I use a metallic tape for some heating stuff, it's certainly not lead, but that's not to say what your looking at isn't!?
Mel Jessop
« Reply #2 on: December 11, 2015, 01:45:06 PM »
In fact the one I use is aluminium based, so it's definitely not lead.. It can be easily torn just like sellotape..
« Reply #3 on: December 11, 2015, 01:47:07 PM »
Wondering if it's the same stuff as the counter balance tape they stick on handles. A quick google earlier showed golfers using metallic tape on clubs, so I assumed it was.
Mel Jessop
« Reply #4 on: December 11, 2015, 01:49:26 PM »
No weight in it really, so my thinking would be it is different stuff..
« Reply #5 on: December 11, 2015, 01:52:06 PM »
No
Mettallic tape is made of high grade material strands bronse brass copper and then coated with plastic.
Lead tape is  an heavy metal and is made of : Lead
« Last Edit: December 11, 2015, 01:58:46 PM by Seniorplayer »
Re: Is Magnetic Tape the same as Lead Tape
« Reply #6 on: December 11, 2015, 02:49:26 PM »
Apologies to everyone who posted. Just looked at the packaging and it's Magnetic tape, doh!
Seems to be used on gold clubs for weight:-
http://golf.wonderhowto.com/how-to/add-weight-golf-club-334041/
springbok45
« Reply #7 on: December 11, 2015, 03:24:13 PM »
I guess it's just a version of lead tape that's easier to apply and remove, as I've only ever adjusted clubs with lead tape.
« Reply #8 on: December 11, 2015, 03:47:06 PM »
It weighs approx a third  more than a normal insulating tape roll, 3oz instead of 2oz. Not sure it's going to make a huge difference unless you use loads of it but it's better than insulating tape.
« Reply #9 on: December 11, 2015, 03:54:58 PM »
Magnetic tape can't be the same as lead tape - lead isn't magnetic!
« Reply #10 on: December 11, 2015, 04:04:20 PM »
Well obviously, I was talking more about it's application as a counter balance.
« Reply #11 on: December 11, 2015, 04:06:12 PM »
If it's heavy enough then don't see why not.
« Reply #12 on: December 11, 2015, 04:07:07 PM »
Depends how heavy 3m of lead tape is?
Sent from my Nexus 5 using Tapatalk
smokem
« Reply #13 on: December 11, 2015, 11:33:01 PM »
And that depends on the width and thickness of the lead tape:
http://www.tennis-warehouse.com/Tourna_Lead_Tape/descpageUNIQUE-PSLT.html
I've purchased lead tape from a UK eBay seller that was heavier than the above because it's thicker (more lead).
simonmay5
« Reply #14 on: December 12, 2015, 12:04:19 AM »
Look at this on eBay
JL Golf 230g Quality Self adhesive Lead tape 100 inches clubs tennis swingweight
Sent from my iPhone
