Author Topic: A bit worried.... ;) ;)  (Read 2217 times)
Cricket_PTY
« on: December 13, 2015, 02:16:37 AM »
Hey guys i just recently bought a Kookaburra Kahuna 600 in India...
Now back in Panama when i begin knocking i just realized this small crack in the bottom edge :
Wht i should do??? is something to worry about ???
will love to hear ur advices...
Cheers...
i12breakfree
Re: A bit worried.... ;) ;)
« Reply #1 on: December 13, 2015, 02:33:37 AM »
Looks like a surface level crack only. I have seen a few SG/kooks with similar cracks. For now I'll suggest put fibre glass tape to cover the bottom surface .
Sent from my ONE A2005 using Tapatalk
SteffanLangholz
    • Teams webpage
« Reply #2 on: December 13, 2015, 08:38:14 AM »
From my perspective, not much you can do. And it won't hurt the bat too much, being level and down low. You would do more damage and harm trying to pry it open and glue it.
Tape and don't use the toe too much ;-)
Sendt fra min ONE E1003 med Tapatalk
« Reply #3 on: December 13, 2015, 11:52:15 AM »
Without a side pics can't see the depth of damage based on the pic I would  leave it or as suggested apply fibre glass.
« Reply #4 on: December 13, 2015, 02:06:04 PM »
If youre really worried superglue it.
I'd leave that personally as it looks to be superficial
inzaghi316
« Reply #5 on: December 13, 2015, 04:43:30 PM »
These cracks wont harm your bat as it can occur even when you are knocking the edges and toes..as suggested by others put the protective sheet and it shld be fine.
Sent from my ASUS_T00G using Tapatalk
114*(53), 100(35), 98*(37), 96(33), 83(44), 79(26),79(34), 68(30), 62(29),59*(30) TOP TEN innings.
Cricket_PTY
« Reply #6 on: December 13, 2015, 08:34:00 PM »
Thanks guys... will cntinue knocking in process then will install a antiscuff sheet...
Cheers...
