Pages: 1 ... 5 6 [7] 8 9
Author Topic: Which B3 shape  (Read 39450 times)
wayward_hayward
Re: Which B3 shape
« Reply #90 on: December 27, 2015, 12:42:33 PM »
Lovely stuff, I was hoping for anything around 2'10. Looking forward to ordering mine in the new year.
Twitter @wayward_hayward
Canners
  • go hard or go home
Re: Which B3 shape
« Reply #91 on: December 27, 2015, 12:43:19 PM »
1lb 10 that will do me nicely
rickjames
Re: Which B3 shape
« Reply #92 on: December 27, 2015, 12:45:49 PM »
Email sent asking for some advice, but I think it's between the DB3, #14 or #19
dcullen8
Re: Which B3 shape
« Reply #93 on: December 27, 2015, 11:21:59 PM »
As someone who is 5'6 and struggles with bats above 2lb8, realistically what are the choices with the custom bats that will weigh/pick up similar to that sort of weight? Assuming gaz cross, #14 and #19 are my only real choices.
Re: Which B3 shape
« Reply #94 on: December 27, 2015, 11:41:12 PM »
@dcullen8 as you're (and this isn't meant to sound as It probzbly does) a shorter player, would a small mens bat be a better option.
@uknsaunders has a full width shorter blade (and maybe shorter handle, I just know It felt small to me) that was a lovely full shape in a low weight.
It could be worth getting something similar mate.
Re: Which B3 shape
« Reply #95 on: December 27, 2015, 11:58:43 PM »
Im 5'7 - worth thinking about a harrow length/ full width bat with either a sh or SSH. It's should save an oz or so in weight/feel a little less long in the hands. I modified Dave's Typhoon profile to create a 2'11 with 45mm edges/60mm spine/high middle/offset edges with this kind of setup.
dcullen8
Re: Which B3 shape
« Reply #96 on: December 28, 2015, 12:23:28 AM »
Great ideas straight away, thankyou! Was holding off til after the new year to send the guys an email, definitely gives me a starting point!
ridhuan
Re: Which B3 shape
« Reply #97 on: December 28, 2015, 07:39:59 AM »
i am also 5'6, prefer Super Short Handle and weight below 2-7
dcullen8
Re: Which B3 shape
« Reply #98 on: December 28, 2015, 08:06:34 AM »
I think if you want to get below 2lb7 the adult light bats are the way to go, 2lb4-2lb6 on the website, or gonwith the above suggestions. Someone with a better grasp will be along to advise though id suspect.
Ams4287
Re: Which B3 shape
« Reply #99 on: December 28, 2015, 08:45:10 AM »
Id suggest one of the DB series shapes (DB1) - if you take a look at the thread they come at a range of weights as a stock shape and are very well balanced
« Last Edit: December 28, 2015, 11:16:01 AM by Ams4287 »
Re: Which B3 shape
« Reply #100 on: December 28, 2015, 09:19:52 AM »
A standard DB1 comes out at 2lb8, shouldn't take much fiddling to get one of those you'd like?
Re: Which B3 shape
« Reply #101 on: December 28, 2015, 10:13:47 AM »
I would suggest the DB1 too which is a great shape wouldn't take much at all to tweak to 2-7.
The adult light is available in the weight you want mate.
« Last Edit: December 28, 2015, 10:15:56 AM by procricket B3 »
Re: Which B3 shape
« Reply #102 on: December 28, 2015, 10:27:47 AM »
What is the standard weight for Mullanator?
Re: Which B3 shape
« Reply #103 on: December 28, 2015, 10:54:37 AM »
2-13 and a half mate Streaky is saying
smokem
Re: Which B3 shape
« Reply #104 on: December 28, 2015, 11:38:35 AM »
Hi Dave. How do #14 and DB1 compare in terms of pickup for the same weight?
