Hammer Vapen LE
Author Topic: Hammer Vapen LE  (Read 3306 times)
Hammer Vapen LE
« on: January 08, 2016, 01:03:03 AM »
And another, sheesh, you'd think I had no life! Oh wait... :-[
A purchase from the SQ eBay page! Originally bought it thinking it looked like a decent looking Vapen Core model, but it turns out it was an LE!
Specs:
Weight - 2lb 10.42oz with scuff and 2 grips
Edge - 34mm
Spine - Approx 62mm
Shoulder - 9mm
Toe Edge - 18mm
Toe - 21mm
Handle - Oval
Concaving - minimal
Right, so a few comments on the bat as a whole before going into a bit more detail. I can't really judge too much on finishing, as this seems to have suffered from a mixture of sticker problems, extensive knocking in and an extremely poorly applied scuff sheet. (Very poorly shaped at the toe)
Onto the general shape, this is a nice duckbill profiled bat, which is becoming very common these days. (Makes sense for a lot of people, you're not meant to score runs there, so why have so much wood there?) The dimensions are nothing crazy, it's a good sized bat for a 2.9 with a single grip. With a gentle concave and a long running spine and a duckbill, you'd expect it to pick up super light, but I would say that the extremely thin oval handle lets it down here. The pick up isn't bad at all, but the thin handle does mean that even I will probably use 2 grips on it. (Normally a one grip man) Same with the Phantom, a very slight bow, nothing drastic. Also the same with the Phantom, around 106mm width at the toe tapering to 104mm. Again, it can make sense the same way the duckbill makes sense, but I personally prefer a pretty full width. (106-108mm throughout)
The performance is unbelievable, I was super impressed when tapping this one up. It could be because it has been well knocked in (there's surface cracking along the grains) but it really is lovely. Exceeded my expectations!
Stickers wise, the front isn't anything exceptional, a good quality vinyl sticker. The grading sticker is actually something I don't really like, it's a small grading sticker up at the shoulder, which will probably crack and come off with wear and tear. (Not ideal, as it's the one which dictates the price of the bat) Back stickers are much more impressionable, with nice embossing and minimalist compared to their previous designs. The finishing actually seems to have been of a really high quality.
All in all, a very decent bat with a very questionable scuff sheet! The actual quality of the scuff sheet is really good, similar to the L&W ones, but would have been much nicer had it been shaped to the toe rather than having straight cuts to ensure it fits on the blade. (A big pet hate of mine is when scuff sheets aren't shaped around the toe!) Not entirely sure who fit it, Hammer or SQ, (I think it would have been SQ) but it would have looked so much more appealing if it had been shaped properly!
sgcricket
Re: Hammer Vapen LE
« Reply #1 on: January 08, 2016, 01:27:06 AM »
Like the look of the bat wrt grains, profile
Re: Hammer Vapen LE
« Reply #2 on: January 08, 2016, 03:35:58 AM »
Chad, I have envied every bat purchase you have made and reviewed thus far; hence, I hate you.  :D
The bow and the profile looks amazing!!!!! How much did you pay for it ?
gaurav23
Re: Hammer Vapen LE
« Reply #3 on: January 08, 2016, 03:54:11 AM »
A butterfly stain under the front sticker ??
Re: Hammer Vapen LE
« Reply #4 on: January 08, 2016, 09:22:01 AM »
I like the Hammer bat with the big bottom.
northernboy1987
Re: Hammer Vapen LE
« Reply #5 on: January 08, 2016, 09:43:27 AM »
Chad, I think it's safe to say that over the past 24 hours you have made us all very very jealous, these are some cracking bats you're posting!
eukaryote76
Re: Hammer Vapen LE
« Reply #6 on: January 08, 2016, 10:13:04 AM »
Ditto on the scuff sheet there @Chad. A bit of a Friday afternoon job with the edges diagonally cut (and being too short). Otherwise fair looking stick!
Re: Hammer Vapen LE
« Reply #7 on: January 10, 2016, 05:18:01 PM »
Good spot! It's a stain of some sort, which might explain the discolouring, which I thought was just oil! No idea if it's a butterfly, or just another stain, but there is something there. :)
You like just about anything with a big bottom, ain't that right? :D
I won the auction at £99.99, so cost me around £106 posted in the end. Cracking buy in my eyes! The performance is certainly up there with the better bats, especially since it's a light one! Ended up changing the scuff sheet it bothered me that much haha, looks much better now!
sanredrose
Re: Hammer Vapen LE
« Reply #8 on: January 10, 2016, 06:27:32 PM »
For 106 GBP this is very good purchase. New bat from hammer is sold for 499 USD. I have a pro model of this bat weight 2lb8oz. My only real issue with the bat is its toe. The ball pretty much sticks to it ..
Pickup wise it's very good and if hit in the sweet spot the performance is real good.
Have you tried Hammer ST ?
Sent using Tapatalk
