Author Topic: H4L Cyber Monday Purchases  (Read 5445 times)
« on: January 09, 2016, 11:15:37 PM »
Had a good rest now, and can keep going! (Bet you all thought I was finished! ;))
Right, so Matt had a Cyber Monday deal with the G2 to G1 upgrade for medium weighted bats. Also had tons of bags and softs on sale, so I went for 2 pairs of NV Pro gloves and a Tempo stand up bag - I now wish I had gone for a pair of pads too! (Couldn't find any in Small Mens, but should have asked about Youths!)
So we'll start off with the bat:
Specs:
Weight - 2lb 10.14oz
Edge - 35mm after rounding
Spine - Approx 60-61mm
Shoulder - 14mm
Toe Edge - 18mm
Toe - 26mm
Concaving - Varied throughout the blade
Right, so I asked for a Hellfire which was as close to 2.10 as possible, and when I received it, it was 2lb 10.1oz. It actually ended up losing some of the weight, and as a result, is only 2lb 10.14oz with a scuff!
Onto the concaving, this one is a bit of a different one, in that it is fairly minimal at the toe, but as you go up the blade, it gets heavier, then reverts to minimal concaving about 6 inches from the handle. I'm actually not a big fan of concaving higher up the blade, as I feel it just affects the response further up more than if you concave a bit more towards the toe. As a result, the response is good, but isn't quite nearly as nice as my other 2 G2 H4Ls, which is a bit disappointing, but it is early doors right now, and you can never tell how much it will just get better with time! Also, these weren't low density clefts, as it was limited to the medium weights, so I can't expect weight not to be taken out some way or another with my request!
The profile of the Hellfire range is gorgeous, as with all the other H4L ranges. It has a lovely flow to it, and has pretty nice dimensions throughout. The handle is an oval one, touch on the thin side, but not overly thin. Aesthetics wise, I think the Hellfire stickers are my favourite from H4L, there's something about the red which stands out even more now. The finishing, as always, is superb, and the grains are lovely. Just a couple of specks probably put it down from being a Pro Grade in looks.
Onto the gloves:
Really top quality glove, I don't normally like splits as much, as often they can feel too bulky, but these are just right. The Pittard palms make the gloves feel nice and supple, and I am a big fan of the fit. They are MRH, but feel almost in between Mens and Small Mens, which is sort of the happy medium for me. :) Top quality protection on all fingers, with reinforced thumb, index and middle finger for the bottom hand.
And finally the bag:
Let's try chucking in the biggest bat we can find:
Yup, still fits fine:
Standing up:
Side to side with a HUGE Island bag filled with bats, naturally:
Odd second deck, which could probably fit flat things like your whites?
Absolutely massive, and probably the best bag I've ever purchased. The materials used are of a high quality, giving the bag a robust feel. The bag itself is extremely spacious, I could probably fit in some keeping gear too if I wanted. The bat caves feel nicely padded, so no need to worry about bats getting damaged badly, and are also spacious, which I suspect a lot of people are going to want after their B3 80mm spined bat purchases. ;)
All in all, really happy with the purchases. Looking forward to take the H4L out to the nets, it will probably be the one to get used first and get the most use, as I want to play it in the soonest! Big thanks to Matt and Adam for handling my questions, and sorting out the delivery! A few hiccups with the courier, but I managed to pick it up in the end!
« Last Edit: January 10, 2016, 06:37:31 PM by Chad »
Ams4287
Re: H4L Cyber Monday Purchases
« Reply #1 on: January 10, 2016, 12:02:08 AM »
Love the hellfire profile it's as good as anything around. Really nice bat Chad, not sure where it ranks on you're mammoth collection but I'm sure somewhere near the top
« Reply #2 on: January 10, 2016, 12:22:50 AM »
Nice review again Chad.
I need me a piano!!
Funny how you describe the concaving as a thought same, first pic from 45degrees I thought "that's pretty concaved"
Then next few pics I was like what? Is this same bat, there's no concaving on these pics.
Are all hellfires like this? Seems bizarre as if want the middle to be meaty and the Edna concaved if any at all.
Number4
« Reply #3 on: January 10, 2016, 12:28:27 AM »
I was just wondering why he has a junior protector in the pictures  :D ;)
JB
« Reply #4 on: January 10, 2016, 07:31:49 AM »
The hellfire profile is one of my favourites, gives a really long middle on the ones I've had. Looks a really nice bat Chad, those gloves were excellent value!
Woodyspin
« Reply #5 on: January 10, 2016, 10:09:34 AM »
Standing up:
Chad does the top section look as though if over loaded will bend and allow things to fall when closed?
Sent from my LG-H815 using Tapatalk
« Last Edit: January 10, 2016, 10:27:12 AM by Woodyspin »
« Reply #6 on: January 10, 2016, 10:21:16 AM »
Did you really need to quote everything for that reply??
Woodyspin
« Reply #7 on: January 10, 2016, 10:24:50 AM »
No ive just got up and im on my phone, its just quicker :)
« Reply #8 on: January 10, 2016, 10:30:44 AM »
It's only quicker if you haven't actually read the entire thread. You've just looked at the pretty pictures and want to reply quickly.
If you read the entire thread and then the replys(which may well have your answer in) it's a lot quicker to hit reply at the bottom than scroll all the way back up to press quote.
Plus then everyone else doesn't have to scroll passed hundreds and hundreds off the same picture on there mobiles to get to read there thread.
« Reply #9 on: January 10, 2016, 01:00:19 PM »
Where are the other 6 dwarves Grumpy? :)
JB
« Reply #10 on: January 10, 2016, 01:13:01 PM »
Dopey is here!!  :D
« Reply #11 on: January 10, 2016, 01:36:00 PM »
Must resist dwarf porn - wife jokes...........
« Reply #12 on: January 10, 2016, 05:31:48 PM »
Haha well with the collection being so good, I think this may struggle to make it to the top! :-[ It will be used in nets to test first, but I think my G2 H4L bats are ahead at the moment!
I need me a piano!!
Yeah, to be honest, I would have preferred a more even concave throughout, with the splice being convex, would probably have meant a more even hitting zone. But eh, I'm not the batmaker, and Matt knows what he's doing! :)
Hey, that's an adult! :D :D :D (Not that I double checked after reading your post...)
Hey, the dividers are really pretty sturdy, and I think the bag comes with 2, so if you're concerned you could probably just double up. The Velcro is top quality and sticks really firmly, so you shouldn't have any problems! :)
« Last Edit: January 10, 2016, 06:14:29 PM by Chad »
sanredrose
« Reply #13 on: January 10, 2016, 06:32:16 PM »
Pick up comparison between hellfire and hattori ? I felt both are the same .. Since you also have both .. Your opinion ?
Sent using Tapatalk
