Author Topic: Broad vs Anderson post 2010  (Read 4016 times)
Aussie In England
  • Aussie father + Kiwi mother = Aussie in London
« on: January 16, 2016, 02:06:39 PM »
So there's a general consensus that Anderson is somehow up there with South African kingpin Dale Steyn, but they way wide of the mark.
More interesting is the respective figures of Broad vs Anderson since 2010 because it's suggested that's when Anderson became Steyn's equal 😂😂😂 #HeadsGone
Any since 2010
Broad
Tests: 66
Wickets: 257
Average: 26.89
S/R: 54.2
5WH: 12
10WH: 2
Anderson
Tests: 68
Wickets: 281
Average: 26.12
S/R: 56.6
5WH: 11
10WH: 2
The stats favour Anderson but more often than not Anderson is only a first innings bowler. Whilst Broad is most likely to bowl a match winning spell from out of nowhere.
So who you picking?
Just in case you wanted to know Steyn's figures in the same period.
Steyn
Tests: 48
Wickets: 234
Average: 21.48
S/R: 43.0
5WH: 14
10WH: 2
Steyn seems pretty decent  :o
"With great power comes great responsibility". Ben Parker
jamielsn15
Re: Broad vs Anderson post 2010
« Reply #1 on: January 16, 2016, 02:11:08 PM »
Home and away splits?
Aussie In England
« Reply #2 on: January 16, 2016, 02:24:26 PM »
Just for you  ;)
Home record
Broad
Tests: 37
Wickets: 166
Average: 24.37
S/R: 48.8
5WH: 9
10WH: 2
Anderson
Tests: 36
Wickets: 162
Average: 24.56
S/R: 53.7
5WH: 8
10WH: 2
Away record
Broad
Tests: 29
Wickets: 91
Average: 31.48
S/R: 64.0
5WH: 3
10WH: 0
Anderson
Tests: 32
Wickets: 119
Average: 28.25
S/R: 60.4
5WH: 3
10WH: 0
Batbuddy99
  • https://royalascotcc.co.uk
« Reply #3 on: January 16, 2016, 02:28:34 PM »
So Broad actually has better stats in England than Jimmy!
« Reply #4 on: January 16, 2016, 02:30:23 PM »
Steyn will go down as one of the great fast bowlers tbf, Anderson and broad won't (decent but not a great)
jamielsn15
« Reply #5 on: January 16, 2016, 02:33:11 PM »
Thank you! I was thinking earlier that broad could be classed as the better of the two....
« Reply #6 on: January 16, 2016, 10:10:56 PM »
Given the flatter decks, bigger bats and smaller boundaries broad and Anderson would go down as greats based on the last 5 years. Not looked up the Windies stats of the 80s but many of the "greats" were averaging similar numbers I think. Makes Steyns numbers even more impressive.
Many greats were known not just for there averages or strike rates but also their longevity. Two bowlers who have 750 test wickets between them, 200 odd tests and show little sign of slowing down, will given a few more years, be known as great for this reason as well.
TangoWhiskey
  • Review that.
« Reply #7 on: January 18, 2016, 02:33:04 PM »
Not sure what your angle is @Aussie In England/Gerry SA but I suppose if you could only choose one of them it would be a horses for courses job. On a pitch that's likely to swing about, there's an argument to be had that you'd take Anderson. If it was a seamers track or wasn't going to swing then you would take Broad.
« Reply #8 on: January 18, 2016, 04:05:17 PM »
Considering we are in batsman dominant era, any bowler who has played for decade(s) and have bowling average of 25 or less should be hailed as a great bowler.
Bowlers have little to no assistance in current era.
Batbuddy99
« Reply #9 on: January 18, 2016, 04:31:06 PM »
but English conditions are always classed as swinging and Broad has better stats than jimmy in eng
TangoWhiskey
  • Review that.
« Reply #10 on: January 18, 2016, 04:42:08 PM »
Not always. Depends on the overhead conditions. English pitches almost always seam about a bit, which could be why Broad has a better average than Jimmy at home. Either way, both of them are fantastic bowlers and would walk into every test side in world cricket at the minute.
ppccopener
« Reply #11 on: January 18, 2016, 04:51:53 PM »
what even Australia?
« Reply #12 on: January 18, 2016, 06:19:10 PM »
Broad would, easily. In Australia Anderson probably wouldn't though, anywhere else no problem. Hazlewood has done very well, but Starc is still not up there as a test bowler, and the Aussies can't even settle on a third it seems at the moment.
Aussie In England
« Reply #13 on: January 18, 2016, 09:08:51 PM »
That's not strictly true.
Starc is the spearhead now that Harris and Johnson have retired.
Hazlewood is the line and length workhorse, his extra pace and height have edged out Siddle.
Pattinson and Cummins are the guys whom Lehmann etc want as the the third fast bowler, but both are injury ravaged.
jamielsn15
« Reply #14 on: January 19, 2016, 08:29:45 AM »
I don't think there's any doubt that Steyn is streets ahead of the rest, but I think you'd struggle to find any nation that, given the choice, would turn down the opportunity to have two bowlers with over 750 test wickets, contributing consistently over almost 10 years in tandem
