Author Topic: Nets Video Camera positioning  (Read 1148 times)
Nothing2SeeHere
« on: January 29, 2016, 12:08:16 PM »
Any advice for most useful positioning of a camera and what camera angles are most useful when filming yourself batting in the nets?I tried clipping a gopro style camera onto the bowling machine last session and although that was interesting, the machine shakes too much during the delivery to be worth a second attempt.
I assume centrally located but is it best to be zoomed out to show the line of the ball? Or zoomed as close as possible to just capture the batsman?
I notice that the pitchvision folks often set up a camera part way down the lane to help with the zoom. Is this a worthwhile practice?
Only asking as my team could do with another batsman and if I'm going to go for it I'd rather get as much from my training as I can - practice makes permanent, only perfect practice makes perfect.
Re: Nets Video Camera positioning
« Reply #1 on: January 29, 2016, 01:12:00 PM »
I try to balance it:-
Show the width of the pitch
Show maybe 50% of the track
Minimise the side view of the netting, otherwise you end up cropping it
Here's not a bad example after 20 seconds, bit too much of the legside netting.
https://youtu.be/ai-c4TrAljs
Also add if you can do it at 60fps then it will be more useful on the slow mo, or pausing mid shot.
« Last Edit: January 29, 2016, 01:16:08 PM by uknsaunders »
« Reply #2 on: February 01, 2016, 05:45:44 PM »
If your on a bowling machine make a mount to attach to a set of stumps(or something else) and place it about 12 yards down the pitch.
Unless your bowling really short you shouldn't touch it with machine and if you play a straight enough drive to take it out then Compliment yourself on a great drive.
« Last Edit: February 04, 2016, 04:36:35 PM by smilley792 »
Nothing2SeeHere
« Reply #3 on: February 04, 2016, 04:16:40 PM »
Thanks for the advice. I have a zoom camera and a tripod so set it at a similar angle to your example. Had a bit more pitch showing (wanted to make sure I could get the pitch of the ball in). I'm using a bowling machine as I am looking to learn some orthodox looking shots.
Only thing I might change is to increase the frame rate next time. Had it at 60fps which worked but I think increasing that would be better for freezing the video at the point of impact to check balance/alignment/head position etc.
