Author Topic: Moisture Levels in Bats  (Read 1620 times)
« on: February 02, 2016, 12:35:45 PM »
Just wondered what the moisture levels in various different makes of bats are? I know Dave has said b3's is 12% and we all have an idea some of the Indian bats are nearer low single figures. Has anybody got a numbers for different brands?
ps. I'm aware Jason Mellet did some moisture readings 2/3 years back but it would be interesting to see the levels on current bats.
Calzehbhoy
Re: Moisture Levels in Bats
« Reply #1 on: February 02, 2016, 12:40:43 PM »
On that as well, how does winter storage affect the levels?
I just chuck my bag into the loft from September--April, should more be done to keep the bat in 'optimal' condition?
« Reply #2 on: February 02, 2016, 12:44:55 PM »
Is there a way to read moisture levels properly that doesn't famed a bat?
I have a prong thing somewhere for checking moisture in fire wood. But I'm not sticking it in my bat! Lol
« Reply #3 on: February 02, 2016, 01:02:35 PM »
Was that when he took the readings of a GM and got 0% because he put the probes on the meter over the scuff sheet?
« Reply #4 on: February 02, 2016, 01:03:19 PM »
Yep
Sent from my Nexus 5 using Tapatalk
« Reply #5 on: February 02, 2016, 01:21:32 PM »
What's the best meter for reading the levels?
Is a cheap one off eBay accurate/reliable enough?
« Reply #6 on: February 02, 2016, 01:41:37 PM »
Be wary of the reading. With the 2 short pronged meters you are only reading the surface moisture level which will vary depending on atmospheric conditions. To get a true reading you need to bore into the material, plug the hole and leave for a few days. Then unplug the holes and use probes to determine the moisture levels.
« Reply #7 on: February 02, 2016, 02:49:52 PM »
^ Construction professionals use a moisture meter that can be placed against the wall to measure moisture in the wall. It also has a setting for wood. I think Stanley Tools makes that moisture meter in the US.
« Reply #8 on: February 02, 2016, 02:53:37 PM »
Be aware, these only test the moisture on the surface of the wall. This is where people get confused between condensation and damp ingress
« Reply #9 on: February 02, 2016, 02:57:46 PM »
Hmmm..good point.
So, there is no way of measuring moisture correctly without drilling holes?
« Reply #10 on: February 02, 2016, 03:12:39 PM »
Hmmm..good point.
Not for the average joe at home, no.
« Reply #11 on: February 02, 2016, 04:16:35 PM »
Ideally you should not leave your bat in a bag or it's sleeve as the willow needs to breath
