Author Topic: Sanding in a concaved bat  (Read 1367 times)
potzy248
« on: February 20, 2016, 07:57:17 PM »
Have had a look on Youtube but with no luck.
Whats the best way to sand a concave back? Is there any electric sanders that can get in there or do you have to get stuck in with your hands?
Re: Sanding in a concaved bat
« Reply #1 on: February 20, 2016, 08:13:37 PM »
If you don't have a drum sander, then by hand is probably the best way
You can wrap your sandpaper round a tennis balls which helps a fair bit
I've also found this sort of thing useful in the past
https://www.ebay.co.uk/ulk/itm/331622951317
wayward_hayward
« Reply #2 on: February 20, 2016, 08:28:23 PM »
If you are doing it by hand, wrapping sandpaper with sponge (I had an old car sponge lying around that I use) works well.
I use a random orbital sander for my refurbs and while concaving is pain in the ass, I use the outer edge of the sander to work from edge to spine. It goes go against the rule of sanding along the grains but I find that I can still achieve a high quality finish.
Twitter @wayward_hayward
potzy248
« Reply #3 on: February 20, 2016, 09:08:18 PM »
Cheers guys.
Yeah looks like by hand is the best option.
