Poll
In mm, can you tell me where the middle is on your bat?
150mm-180mm
- 5 (26.3%)
180mm-200mm
- 1 (5.3%)
200-220mm
- 7 (36.8%)
220-240mm
- 4 (21.1%)
240-260mm
- 1 (5.3%)
Higher than 260mm
- 1 (5.3%)
Completely outside these ranges?
- 0 (0%)
Total Members Voted: 19
Author Topic: Where is the Middle on your Bat?  (Read 3803 times)
« on: February 24, 2016, 03:56:47 PM »
Would be interesting to know where people have their middles, their height and the type of bat.
Woodyspin
Re: Where is the Middle on your Bat?
« Reply #1 on: February 24, 2016, 04:38:01 PM »
Mid - low, 6'4", oblivion e41.
« Reply #2 on: February 24, 2016, 04:39:59 PM »
Wouldn't have a clue, I only use the toe and the edges  :-[
« Reply #3 on: February 24, 2016, 04:47:47 PM »
Used the crictech sheets, and measures all the cracks in my bat, was around 14 to 20cm so had a bespoke bat made at b3, with the bulk and middle put here. Used the b3 last season and had my best season ever.
« Last Edit: February 24, 2016, 06:28:31 PM by d7bow »
« Reply #4 on: February 24, 2016, 04:49:55 PM »
Below the top and above the bottom 🙈🎣🙈🎣🙈🎣🙈
simonmay5
« Reply #5 on: February 24, 2016, 04:54:00 PM »
I really could not tell you as I have to many bats 🙈
« Reply #6 on: February 24, 2016, 05:12:14 PM »
Took a couple of rough measurements and it's around 220mm
Mid to high middle,  5'7 -  f18,  rk, red ink, b3.
« Last Edit: February 24, 2016, 05:43:40 PM by uknsaunders »
Akewstick
« Reply #7 on: February 24, 2016, 05:20:03 PM »
Is there a way of calculating this to the millimetre? or do you just measure to the thickest point?
« Reply #8 on: February 24, 2016, 05:33:22 PM »
Either look at the spine or tap up with a mallet. It only has to be to the nearest cm, not to the mm  ;)
StillNotOut
« Reply #9 on: February 24, 2016, 05:36:20 PM »
Mid to Low middle.
5'7
Red Ink Custom X3, SS Ton Players, MRF Genius X and an Adidas Pellara wet bat
Thesmiff
« Reply #10 on: February 24, 2016, 05:38:24 PM »
Low middle 6'2" Newbury samurai Cadbury refurb
Kevtheplumber
    • K Fisk Plumbing & Heating Ltd
« Reply #11 on: February 24, 2016, 05:59:21 PM »
I'm 5'7. Both my slazenger weighing 2-8 and Aldred at 2-14 are 220mm from toe.
Twitter @kfiskplumbing
           @KimboltonCC
Woodyspin
« Reply #12 on: February 24, 2016, 07:04:17 PM »
I like this idea alot
« Reply #13 on: February 24, 2016, 08:19:05 PM »
Halfway up from the bottom of the bat
« Reply #14 on: February 24, 2016, 08:20:05 PM »
I have never found it.
