Long blade bat
Author Topic: Long blade bat  (Read 15132 times)
dickyboy
Long blade bat
« on: March 10, 2016, 10:50:11 PM »
Hi
Not sure where to post this but I'll try here.
I'm looking to get a longer bat.  Not sure wheteher to get a long handle or long blade...Opinions please?
But my main question is; I live near Gatwick, Can you point me in the direction of the nearest bat makers please?  I'm considering a custom bat, I have seen Phantom and Aftab was really great with his products but I'd like a second opinion and ideally speak to a bat maker.
I'm 6'4", mainly a bowler but converting to batting.  Play league on saturdays and friendlies sundays.  I now open the batting. I pretty much only play the drive (or at least everything off the front foot)
Who is the best ad nearest to help me please?
Thanks in advance
Rich
Woodyspin
Re: Long blade bat
« Reply #1 on: March 10, 2016, 11:01:42 PM »
Who do you play for rich? Closest is either H4L which has very high praise off here Newbery (brighton) Chase near basingstoke, Dunamis (Gosport) not sure of any others
skip1973
Re: Long blade bat
« Reply #2 on: March 10, 2016, 11:05:13 PM »
Long handles only help if you hold the bat very high, long blades are the way to go.
simonmay5
Re: Long blade bat
« Reply #3 on: March 10, 2016, 11:33:44 PM »
I would suggest making contact with Matt and he can make you a long blade to your speck or long handle he has some very serious willow in at the moment and I am sure your find something you like if not plenty of great sponsors on hear I sure Asad at Uzi or Jake at vitas can sort something out as well
Jogetnz
Re: Long blade bat
« Reply #4 on: March 11, 2016, 07:06:15 AM »
I had a long blade made by H4L for a friend, he's played a heck of a lot of cricket and it's the best bat he's had.
roco
Re: Long blade bat
« Reply #5 on: March 11, 2016, 07:53:19 AM »
I'm 6ft4 and trialled long blade and long handle but found long blade much much better
had them from most makers around as like to try new things
current ones im using are from H4L and aldred which are both top notch
trypewriter
Re: Long blade bat
« Reply #6 on: March 11, 2016, 09:18:58 AM »
I believe 'Tall' Paul from IJC uses a long blade H4L and rates it very highly.
Here it is : https://www.youtube.com/watch?v=nhLiWHQMBAo
« Last Edit: March 11, 2016, 09:24:08 AM by trypewriter »
SirScottiod
Re: Long blade bat
« Reply #7 on: March 11, 2016, 09:41:58 AM »
At what height do you need to be to warrant a long blade? or is it just preference?
All the No gear, No idea :D
roco
Re: Long blade bat
« Reply #8 on: March 11, 2016, 09:48:57 AM »
just preference I think as I'm sure chanderpaul used a long blade and he was small but some 6ft+ people on here don't use them
in my opinion when you pass 6ft you should look into them to see if they suit you as it has helped me greatly with the way I play and more comfortable at the crease plus the middle seems to be more where I need it
trypewriter
Re: Long blade bat
« Reply #9 on: March 11, 2016, 09:53:12 AM »
It's worth checking the vid - Paul explains why he uses one.
dickyboy
Re: Long blade bat
« Reply #10 on: March 11, 2016, 10:06:03 AM »
I play for Abinger Sundays and think I'm playing for Horstead Keynes on Saturdays as I fancy seeing some Sussex grounds now I've moved to the Gatwick area.
I'll look at Dunamis, Uzi sports and Vitas.
SimonMay, How do I contact Matt? Who is he etc?
I'll take another look at H4L as people keep rating them but I just didn't fall in love with them.
I really like the look of Phantom bats but I'd like to speak to the person making the bat etc. They had suggested long handle but now I'm thinking long blade.  I really like the 2x custom bat deal, one to practice with, one to keep for matches.
  I get yorked a lot, play straight over the top of balls that bounce low and feel I'm having to stoop; I play very upright on the front foot. Plus the majority of the balls I hit cleanly are on the low side of the middle, therefore the ones that are slightly low are getting towards the toe.
Definitely going to get a longer bat,
Re: Long blade bat
« Reply #11 on: March 11, 2016, 10:12:53 AM »
I'd say over 6'3" as a rough guide as I'm that height and for me it's borderline whether to use one or not, have used them with great success in the past but mostly use SH these days. Don't think they make a huge difference unless you're exceptionally tall or get yorked a lot, it's more about getting the middle in the right place which can easily be done with a normal blade. By no means is there any kind of rule though, if someone is 5'2" and feels they bat better with a long blade then why not use one.
edit: @dickyboy if you're getting yorked a lot then a long blade is definitely a good option, that was what led me to try them at first in my younger days and it 100% helped. Never owned a LH but tried other peoples' and hated them.
« Last Edit: March 11, 2016, 10:15:29 AM by edge »
SirScottiod
Re: Long blade bat
« Reply #12 on: March 11, 2016, 10:16:47 AM »
I'm 6'1 but well built (and quite fat) just thinking it might help keep me up straight and therefore playing straighter
Re: Long blade bat
« Reply #13 on: March 11, 2016, 10:19:54 AM »
Don't see that it would help with that? Some people do like the extra length on the grounds that it makes it more comfortable to lean on the bat in your stance, but you should straighten up when playing the ball anyway and as soon as you pick the bat up there's no difference to how you move through the shot.
Re: Long blade bat
« Reply #14 on: March 11, 2016, 10:42:13 AM »
You'll have to get in the queue to meet that batmaker, he doesn't deal with the public.
I can arrange for you to visit hunts county bats and have a bat made in front of you. G1 is £185 and I'm sure we could arrange for a cheaper grade as a net bat to be made at the same time.
I can also arrange for you to visit Gray Nicolls for this, but you won't get much change out of £1000 I'm afraid. Don't shout at me I don't set the prices :)
I'm ioen to being corrected but Dunamis have been forum sponsors for a while now and I'm yet to see anything suggest they make their bats.
I would reccomend Matt at h4l, the brand has been incredibly popular for us this year and we've done a number of bespoke bats for people, of course if you want to visit you may as well go straight to him as he is a fellow forum sponsor
