Poll
SS supertest Indian (RH) Mens size is the same as :
Mens UK Regular
- 3 (17.6%)
Small mens UK
- 7 (41.2%)
Youth UK.
- 1 (5.9%)
Something else.
- 4 (23.5%)
I don't know.
- 2 (11.8%)
Total Members Voted: 14
Author Topic: ss super test gloves Indian mens (size) = Small mens (Uk) or = Youth (Uk)  (Read 4915 times)
Cricketfan99
I'm looking to buy a pair of ss super test gloves in RH, but in youth size. I am confused to their sizing.
I've contact OLS they say indian mens size is smaller then Uk mens size, "about small mens". I said i need the exact size , no guess work, therefore i need 100% conformation to its exact size. if its same size as uk youth. then fine, but if its same as small mens uk or your not 100% sure, then leave it. Otherwise it will return it unless I'm happy. They offered to refund me. So as i can buy it from cricket direct in uk, (they are more expensive then buying direct from india but at least i know the exact sizing and can return them easier) which sell both mens and youth gloves.
i contacted cricket direct the only retailer i see that sells them in uk size. i asked them what (exact) sizing is their, and they said the youth is standard youth, and mens is standard mens (i.e standard uk mens). i said fine.
basically is the question is:
Indian mens (size) = a) Small mens (Uk) or
b)  = Youth (Uk)
« Last Edit: March 15, 2016, 06:31:33 PM by Cricketfan99 »
Z.Rana
By from a reputable UK dealer and try them on
well past my peak
a very nice glove, I wear a Standard Mens therefore when I order from India I order OS size which is prefect. I have also purchase the Indian Mens size which is just a little snug but only take a session or two and they seem fine.
Kevtheplumber
    • K Fisk Plumbing & Heating Ltd
I've got 3 pairs from Ols. Few mates with larger hands have some also. I'd say they are larger than youth but smaller than standard men's which suits me
Twitter @kfiskplumbing
           @KimboltonCC
So, Small Men's then?  ;)
Kevtheplumber
Pretty much yes
           @KimboltonCC
alba caerulea
Small mens and Indian mens are very similar in my experience, and I use both without any problems
I had Uzi Green Mamba in youth which are definitely smaller than SS Whiteouts which are Indian mens.
So Indian mens is small mens in UK.
Bat and Ball Cricket
Like shoes, you'll find a variance in size between brands anyway.
I've got two sets of SS Limited Edition batting gloves and have had a few sets of SS batting gloves as well.
All of these have been a smaller size, but i'd call them a more snug fit, rather than small mens.
I've got pretty long fingers and find the indian/sub-continent brands snug, but not too short.
Australian brands, in small mens, the fingers aren't long enough.
Hope this helps.
Cricketfan99
most probably will. thanks. !
Z.Rana
Cricketfan99
nice to know.
out of interest will you fit into a youth size glove in uk. and or after a few try ones, will the same youth size fit or will it be tighter then the standard indian gloves. (which appears may be similar to small mens uk)?
Z.Rana
Cricketfan99
OK. good thanks
again, same q to you also:  will your hands fit into a youth uk glove? if not then id say the standard indian gloves are bigger then a 'uk youth' but smaller then a standard 'uk mens' , therefore about a small mens?
Z.Rana
Cricketfan99
Hope this helps.
your right, as eg the Ca standard mens is like slightly bigger then normal mens, maybe a oversize mens almost. etc... yes so there is a variation in some brands to say the least.
again, same q to you also:  will your hands fit into a youth uk glove? if not then id say the standard indian gloves are bigger then a 'uk youth' but smaller then a standard 'uk mens', therefore about a small mens? but you say not quite a uk small mens. so this is interesting.
Z.Rana
Cricketfan99
ok thanks, i think prob, the most helpful answer. as you can have tried uk youths and you say they are smaller then the indian mens size. which makes sense. as i cant imagine indian mens being same as a youth size. that is just too small. i think.
Z.Rana
Cricketfan99
thanks for the reply.
Z.Rana
