Author Topic: Renegade T20 cricket bat from Procricshop, USA.  (Read 939 times)
sanredrose
« on: March 24, 2016, 06:07:14 AM »
I was hunting for a T20 style bat for a while now. Most offerings had a shorter blade and longer handle. I was looking for something similar to an old Newbery model with reduced shoulders. Finally found a reduced shoulders model at Procricshop and decided to give it a try.
Specs
* Weight - 2lb 11.4oz
* Edge - 36 mm
* Spine - 58 mm
* Mid to low but has an extended sweet spot
* Very mild bow
* Oval handle
Bat weighs about 2lb11oz with 36mm edge size and 58mm spine height. It has about 2mm scalloping and it picks up atleast 1oz lighter than the dead weight. My regular bat is a Kahuna 1000 - 2lb11oz and this bat feels lighter than that one. Concave profile plus counter balance handle definitely helps in pick up. Ping is very good but the willow is a bit on the softer side. I have started knocking the bat and will post more updates on how it performs ...
Front view ...
Profile view ...
Counter balance on the handle ...
Sloped shoulders ...
« Last Edit: March 24, 2016, 06:24:53 AM by sanredrose »
