Author Topic: Toe Crack  (Read 2093 times)
LeftHander52
Toe Crack
« on: April 25, 2016, 07:31:24 PM »
So after being a lurker on this forum for the last two months, I unfortunately got a very good reason to make my first post and create my first thread.
Bought a new bat, thought that knocking in went well as there weren't any more seam marks left on the face, so bat was waxed and face sheet fitted. Since it's now off season here, it then went in hiding in my cupboard for two weeks... I was sniffing around to play some LMS cricket and a team offered to let me play yesterday and I decided why not use my new bat! Everything was going really well, bat has a sweet middle, then silly me tried to overhit a yorker....
So I've got some photos of the damage, just need some opinions on what the best plan of action is.
Seems like the damage was partly because I really didn't give the toe enough time with the mallet and when we went out to field I realised the 2 piece ball we use is quite a bit harder than the 4 piece I'm used to! The crack is somewhat visible from the bottom of the bat, it's just too much hassle to try and take a photo while pulling the toe guard out of the way.
I was thinking wood glue and clamp a bit of work with sandpaper, wax and then a new scuff sheet and some tape around the toe? What I'm not so sure about is how to go about knocking the toe in more, before the glue session or after?
Opinions and advice will be greatly appreciated!
tom line
Re: Toe Crack
« Reply #1 on: April 25, 2016, 07:39:24 PM »
How deep does it go? If it doesn't go that far through the toe then Paul aldred put a good video up recently on YouTube, a bit of liquid super glue and sand whilst still wet and then start knocking in on the crack closes it together and then leave the wood glue to fully dry.
LeftHander52
Re: Toe Crack
« Reply #2 on: April 25, 2016, 07:46:49 PM »
Easiest way to explain is if you had to look at the toe of the bat, the crack travels in a slight arc from the one visible on the face to the one on the edge. I'd say about 10mm in from the sides on the face and then 15mm back from the face on the edge, goes about 10mm deep into the toe, so I don't think very deep?
hanif
Re: Toe Crack
« Reply #3 on: April 25, 2016, 09:33:38 PM »
This is a very common occurrence, especially when the bat is fairly new. People get a little horrified and think the bat is wrecked. I think Paul Aldred created a very good video review of how to deal with these minor cracks. It is a quick fix and very simple to do and is some thing every one can do with a few simple cheap pieces of kit. Majority of surface cracks can be easily fixed and is very simple to do.
