Author Topic: Batting Technique  (Read 4132 times)
OllieWalker39
Batting Technique
« on: May 24, 2016, 12:57:32 PM »
Needing some help unfortunately! Other than one good knock, I've been in horrific touch this year. I seem to be coming from outside the line of the ball and through it if it's on the stumps - if it's outside off I'm fine. It's never normally a problem, but this year I've been out bowled twice already!
Are there any things in someones technique that could cause / cure this? I know it's difficult without seeing any footage but (un)fortunately! there's none haha!
If anyone has any ideas please let me know - don't fancy being dropped!
GoodLeave
Re: Batting Technique
« Reply #1 on: May 24, 2016, 01:07:44 PM »
New bat. There, I said it.
Without footage it's almost impossible, how's your footwork this season? It sounds like you're coming around your front pad?
OllieWalker39
« Reply #2 on: May 24, 2016, 01:22:45 PM »
I thought new bat as well... ;)
I know it's hard haha! My footwork has been pretty consistent in fairness. I think coming round my front pad could be the cause - as it sees me being bowled through a gate that shouldn't be there. It's like I'm getting there way too early and just giving up on the shot!
Could it be a thing of just waiting for the ball and being more positive?
I'll try get a net and video footage but it's difficult!
« Reply #3 on: May 24, 2016, 01:28:57 PM »
Check your grip is ok and your stance is not closed/too open would be where I would start, but without seeing a clip of your batting it is hard to judge.
Calzehbhoy
« Reply #4 on: May 24, 2016, 01:35:10 PM »
May be very basic but this vid helped me out a fair bit this winter. Feel so much more comfortable, had changed my cricket grip to my golf grip without realising.
https://youtu.be/dTRx3cUDfXo
OllieWalker39
« Reply #5 on: May 24, 2016, 01:37:39 PM »
I'll give that a go - it may be I'm too closed off (especially as I was bowled by a Left-Arm Over on Saturday) - seems reasonable if I'm closed off, I'd have to play round my pad - creating a rather large gate to be bowled through! I'll have a check of the video as it seems to be only something I've started doing this winter! Really annoying as I used to be solid, only being removed by good bowling - now, twice in five innings, I've been bowled by a fairly normal delivery!
I'll give that a go - and if I can I'll get some video! But I struggle with pictures onto here, never mind a video  :D
Butterfingerz
    • Stealth Cricket
« Reply #6 on: May 24, 2016, 01:41:25 PM »
You can change anything you want but if you're not keeping to the basics it doesn't make a jot of difference, If your being bowled too often ask your self is the bat coming down straight??
« Reply #7 on: May 24, 2016, 01:42:30 PM »
A few possible reasons:
1. Wide hands.. instead of hands going back close to your body, your hands actually push out away from your hip. This creates many issues, one of which you seem to be facing. Another symptom of this fault is that your straight/on drives end up on the off side (sliced).
2. Head falling over to the off side, instead of going into the ball.
« Reply #8 on: May 24, 2016, 01:47:36 PM »
Do you have a trigger movement? If so stop it. Otherwise keep your eye on the ball and your form will soon return
OllieWalker39
« Reply #9 on: May 24, 2016, 03:23:38 PM »
Think I need a video / get someone to look don't I.
I'd say twice in 7 innings is too often for an opener. Shouldn't really be happening.
When you say wide hands I'm guessing you mean my hands being away from my body in my stance? Trigger movement - minor but has been the same for a couple of seasons and never caused trouble - gets my feet moving and I struggle more going back so it helps quite a bit I've found.
The Cricket Boutique
    • The Cricket Boutique
« Reply #10 on: May 24, 2016, 03:34:50 PM »
I found this helped me even though it does sound a bit random.... I used a pool cue or a broom handle and picked it up as a bat, I would then practice my normal drive straight down the ground with this (obviously not using a ball). Because the cue/broom handle is so much longer it exaggerates the angle that you are playing your shots at so you can see the angle it is coming down at. I found that what I thought was my straight drive was actually coming down at a big angle and hence the reason I was hitting (or not hitting) straight shots to leg (or playing all around a straight one).
You may also find that your head is falling away to the off side too much.
You could also need a new bat  ;)
jd163
« Reply #11 on: May 24, 2016, 03:51:25 PM »
Your batting video will definitely help in providing a proper advice.
Got wood!
GoodLeave
« Reply #12 on: May 24, 2016, 05:43:22 PM »
If you're worried about coming around your pad, and feel you're trying to fetch the ball and not waiting for it to come to you, I think ABDV's box theory is for you. Failing that, check Buzz's batting book stance video.
https://youtu.be/6VHpsphdSrE
jd163
« Reply #13 on: May 24, 2016, 05:50:42 PM »
ABD's videos helped me a lot specially the grip part.
Got wood!
« Reply #14 on: May 24, 2016, 06:45:45 PM »
Simple tip is to brush your top hand glove against  the top of your front pad  doing this closes the gap between bat and pad ensuring you don't get bowled  through the gate.
« Last Edit: May 24, 2016, 06:47:36 PM by Seniorplayer »
