Author Topic: Aldred Velocity butterfly  (Read 4347 times)
jd163
« on: June 08, 2016, 07:17:35 AM »
Ordered my 3rd bat from Paul as last two were bought by my teammates. Requested a 2-14 ,full profiled Velocity shape in butterfly grade and Paul delivered 100%. Ping is fantastic as usual for all Aldred bats. Pick up definitely feels like a 2-13 with a slight bottom heavy feel which is totally fine with me. This bat was ordered to take the beating from cheap rock hard balls used in our local T20 league. Finishing is also top notch.
Specs
Edge: 36mm
Spine: 67 mm
Grains: 6
Weight: 2-13
Pick up feel: 2-13
Sweet spot: low
Balance: slightly bottom heavy
Handle: standard thickness with black spiral grip
Got wood!
gaurav23
Re: Aldred Velocity butterfly
« Reply #1 on: June 08, 2016, 07:25:10 AM »
Good honest review there mate. You got everything going right there - butterflies at the perfect spots & dominant only on the back,straight grains all the way to the back of the bat, brilliant full shape, superb finish to it too. Great deal scored now score heaps with it :)
jd163
« Reply #2 on: June 08, 2016, 07:32:58 AM »
Thanks gaurav23.. I specially requested this type of cleft. This looks like a grade 2 and got the strength from butterfly stain.
Got wood!
Garmatthews
« Reply #3 on: June 08, 2016, 07:46:00 AM »
Beautiful Bat, can't go wrong with Aldred
Ridenmarke
« Reply #4 on: June 08, 2016, 08:04:39 AM »
That's a striking butterfly
leatherseat
« Reply #5 on: June 08, 2016, 10:14:59 AM »
Paul does make some lovely bats. I also think his videos and posts have been amongst the most informative contents of this forum.
Enjoy,
David
raza147
« Reply #6 on: June 08, 2016, 10:36:33 AM »
i brought an aldred butterfly as a net bat, but i am now using it as one of my match bats because it is soo good, good luck with yours
Jlscarroll17
« Reply #7 on: June 08, 2016, 03:56:35 PM »
Looks a stunner
dannyhall04
« Reply #8 on: June 08, 2016, 04:19:41 PM »
That fourth picture down... is the spine slight off centre? Sure it won't affect anything but I'm second guessing myself now and can't make my mind up  :D :D
jd163
« Reply #9 on: June 08, 2016, 04:24:39 PM »
Looks like it.. i will check it one more time later in the day.
Got wood!
