Author Topic: My Newberry UZI 5*  (Read 12849 times)
sunny_Kris
My Newberry UZI 5*
« on: June 23, 2016, 03:25:37 AM »
hey guys,
 Got myself a newberry UZI to play tennis ball cricket (sacrilege?) and am mighty pleased with it. Got it from Paul and team at IJC(www.itsjustcricket.co.uk) and based on Paul's recommendation got myself the 2.9 that picked up and tapped up better than the 2.7 that he had in stock. As always, dealing with IJC is always a pleasure and their customer service is as good as it gets in terms of response time and patient answers to all the teeth gnashing questions online buyers throw at them (i know i do!).
 The bat came with a hammer edge scuff, but i removed it to oil and knock the bat (follwed the sage advice provided by Ginger: http://custombats.co.uk/cbforum/index.php?topic=32421.0). But for some reason, i spent more than 4 hours knocking it in (oiled it 4 times - maybe its the AZ dry climate that makes bats soak up oil soon). But i'm mighty pleased with the end result. the bat is a rocket launcher
here are some pics:
Cheers,
Sunny
Ridenmarke
Re: My Newberry UZI 5*
« Reply #1 on: June 23, 2016, 06:54:44 AM »
The grains seem very defined, probably has been oiled sufficiently.
« Reply #2 on: June 23, 2016, 07:23:41 AM »
Bat looks decent but what have Newbery done with their stickers!
sunny_Kris
« Reply #3 on: June 23, 2016, 03:04:03 PM »
 Yes, I had oiled it 4 times with at least 6 hours between each oiling knocked it till the grains started to widen.
Cheers,
Sunny
sunny_Kris
« Reply #4 on: June 23, 2016, 03:04:49 PM »
 Oh you don't like these? check out the new Quantum L.E :o
Cheers,
Sunny
« Reply #5 on: June 23, 2016, 03:13:42 PM »
Hmmmm, stickers aside, there's something about Newbery. I really, really want an Uzi and a TT.
sunny_Kris
« Reply #6 on: June 23, 2016, 03:17:52 PM »
 the UZI works best for a players taller than 5"11' or 6";i was not veery comfortable picking it up and got the grip replaced with a thicker, heavier one to improve the pickup. But one of my team mates who is 6"2 had a lot of fun playing with it :)
Cheers,
Sunny
i12breakfree
« Reply #7 on: June 23, 2016, 03:48:44 PM »
That's a nice bat. One question though, does the willow quality matter if you are only using it for tennis ball ? The ball is anyways going to bounce if its EW or KW .
sunny_Kris
« Reply #8 on: June 24, 2016, 04:44:26 PM »
let me put it this way, i have tried inexpensive KW bats (GN Evo slayer) and high end bats (T-rapta Fury 100, L&W Reserve) in tennis ball matches and found the following:
 i) the ball flies off the bat irrespective of the willow - if you middle it
 ii) if you don't middle the ball, a grounded shot is better with a cheaper quality willow as the ball will most probably not carry all the way due to:
     a) There is not as much wood in a lower quality bat as a more expensive bat (for the same bat weight)
     b) bat speed / pickup is not optimal for a lower quality bat by virtue of the bat design and you will get the best momentum with your swing. For example, a 2.14 KW from a random vendor and a 2.14 EW designed by L&W, will pickup very differently.
 Also, since the tennis ball bounces much more unpredictably than a leather ball, you really want a light weight bat that has a lot of wood to ensure your shots are traveling the distance. if you can find a KW bat that has good balance with a light pickup, sure - go for it!
« Last Edit: June 24, 2016, 04:46:42 PM by sunny_Kris »
Cheers,
Sunny
Batbuddy99
  • https://royalascotcc.co.uk
« Reply #9 on: June 24, 2016, 06:16:59 PM »
Surely you don't need to knock a bat in either if it's only being used against a tennis ball?
i12breakfree
« Reply #10 on: June 25, 2016, 02:52:54 AM »
that does hep explain your selection.
Fine EW bat made by a reputed brand will definitely give you a better balanced bat
IQ
« Reply #11 on: June 25, 2016, 03:03:34 PM »
bat looks great quality, these new Newbery stickers look fake as! Who designed the font on the toe piece especially! :o
For tennis ball cricket overdried clefts are great as there is lesser possibility of damage with time. Even well made kashmir willow do very well.
sunny_Kris
« Reply #12 on: June 27, 2016, 06:07:34 PM »
 True that. i just knock it in because i like getting to know my bat and might use it in a leather ball match. But mostly because I just love the sound a ball makes on a well knocked bat :)
Cheers,
Sunny
sunny_Kris
« Reply #13 on: June 27, 2016, 06:08:18 PM »
 do you know any vendors who sell light weight, well made KW bats?
Cheers,
Sunny
« Reply #14 on: June 27, 2016, 06:09:34 PM »
Is it a satisfying wack like you've hit it with a tennis racquet?  ;)
