Author Topic: Bat Care After Becoming Wet  (Read 1989 times)
Curtisj77
« on: July 08, 2016, 09:21:02 PM »
Hi all, I am seeking advice please... Unfortunately my bat got slightly wet while being used in a training session and just as an precaution was looking for advice on what to do next??
Thanks Curtis
Re: Bat Care After Becoming Wet
« Reply #1 on: July 08, 2016, 09:25:14 PM »
Let it dry out. It will be fine.
« Reply #2 on: July 08, 2016, 09:26:14 PM »
Buy three new bats.
A new match bat.
A new wet weather bat
And a new net bat to protect the other two whole in practice........
« Reply #3 on: July 08, 2016, 09:32:32 PM »
Buy three new bats.
A new match bat.
Exactly what @smilley792 has prescribed... except I'd multiply these by 2 (one light, one heavy..for each).
jd163
« Reply #4 on: July 08, 2016, 09:52:34 PM »
Dont forget matching gloves & pads to go with ur new bats 😀
Got wood!
Jlscarroll17
« Reply #5 on: July 08, 2016, 10:17:17 PM »
Let it dry out, lightly sand the bottom and get a little bit of oil back into it that's what I do works every time or buy some shoe goo and place a good think layer on the toe to stop water entering the wood
langer17
« Reply #6 on: July 08, 2016, 10:17:48 PM »
My bat got some water through the face near the toe. The wood expanded which isn't the issue, it became an issue when the wood dried as the wood may crack/feather near the toe as it seems to shrink in that spot where it dries,  as mine did. Even if it does, I just put some super glue in there (only a small crack so super glue was fine. Would use wood glue it it was a large one) then sand and oil.  Hasn't had any issues in 4 years since
« Last Edit: July 08, 2016, 10:20:18 PM by langer17 »
« Reply #7 on: July 09, 2016, 10:08:46 AM »
Put it somewhere airy and allow it to dry out thoroughly wouldn't  use it until it has.
« Last Edit: July 09, 2016, 10:10:25 AM by Seniorplayer »
