Pages: 1 2 [3] 4 5 6
Author Topic: XP80 or not  (Read 16765 times)
ogroupleader
Re: XP80 or not
« Reply #30 on: August 03, 2016, 09:22:06 PM »
Get a legend stand bag.
Australian fast bowler
Re: XP80 or not
« Reply #31 on: August 04, 2016, 12:01:25 AM »
Just Curious where you ordered from to be able to get a inch shorter blade and longer handle? Doesn't that defeat the whole purpose of buying a off the shelf bat? I wouldnt think Gray Nic would just do something like that as a special order without serious price tag, care to share how much it cost you?
i12breakfree
Re: XP80 or not
« Reply #32 on: August 04, 2016, 01:11:45 AM »
That's a beautiful stick. Hope they sort you out with correct specs .
skip1973
Re: XP80 or not
« Reply #33 on: August 04, 2016, 01:26:27 AM »
I'd be keeping that,rare as hens teeth. I could sell it 20 times over.
Ridenmarke
Re: XP80 or not
« Reply #34 on: August 04, 2016, 02:32:01 AM »
Gee that's a beautiful rare beast
ogroupleader
Re: XP80 or not
« Reply #35 on: August 04, 2016, 08:02:44 AM »
They will make anything you want within reason.
Pretty sure you have the option of ordering everything from the silver upwards in custom specs.
I would think its only an off the shelf bat if you buy it off the shelf???
If you like the profile of a bat but it's not exactly to your preferred spec why wouldn't you have it tweaked?
When i placed the order the price was not going to be any more than the standard price for this bat.  Keep in mind these are $975 in stores. Pretty hard to justify charging more than that when it's simply a matter of cutting one bit shorter and the other bit longer.
Re: XP80 or not
« Reply #36 on: August 15, 2016, 01:20:41 PM »
A bit confused about the weights/ sizes..Apparently the XP80 is also offered in light weights....does anyone know if the dimensions are the same ?
Mpt7
Re: XP80 or not
« Reply #37 on: August 15, 2016, 01:39:11 PM »
batpic = yum
ogroupleader
Re: XP80 or not
« Reply #38 on: August 16, 2016, 11:40:21 AM »
Just checked the gray-nic catalog and it says weights start at 2lb 9.
I haven't measured the spine height on this but I'm sure it is at least 80mm. Edges are 24mm. I have seen other heavier bats at gccc and the edges on those don't look to be any larger than these.
ogroupleader
Re: XP80 or not
« Reply #39 on: August 16, 2016, 11:50:21 AM »
I did have a chance to use it in a short ball machine session  on Friday. Cannot fault the response at all. Sweetspot also seems to extend very low - well below the swell. Can't wait to do a proper net session but might not get a chance before the game this weekend.
acko109
Re: XP80 or not
« Reply #40 on: August 16, 2016, 06:56:29 PM »
its beautiful!
Re: XP80 or not
« Reply #41 on: August 16, 2016, 07:20:19 PM »
Can someone please say its a waste of money, so I can save myself some cash?
    • Neon Cricket
Re: XP80 or not
« Reply #42 on: August 16, 2016, 07:42:09 PM »
It's a waste of money...
It totally isn't, you should buy one IMMEDIATELY
Bats_Galore
Re: XP80 or not
« Reply #43 on: August 16, 2016, 08:59:13 PM »
Firstly I would love to own one of these bats. Given the performance of the xxx9 gray nics and the Warner replica I have, I imagine the performance of these bats would be outstanding. However if the restriction of bat size comes into force, can someone tell me if we would still be able to use the over sized bats, if not it's a lot of money with the current exchange rate, shipping and duties/vat etc. I am already mildly annoyed that the other 2 would potentially become unusable. However it also means it is likely to be a one off opportunity to buy it...
ElPerro
Re: XP80 or not
« Reply #44 on: August 17, 2016, 06:18:32 AM »
If any restrictions do come in then its most likely it'd only be enforced at the professional level
